LS Upgrade Oil Pan
Old May 11, 2017 | 06:26 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
LS Upgrade Oil Pan
I've notched my factory k-member and it fits the stock oil pan great. I'm building up a motor where proper oiling will be a major importance.. Drag racing and maybe a road course. Car is also lowered.
What upgraded oil pans are people running while maintaining ground clearance.
Thanks in advance.
Old May 11, 2017 | 09:52 AM
Beater79TA's Avatar
Re: LS Upgrade Oil Pan
The 1998 - 2002 FBody pan is probably the best clearance unless you're running a drysump. If you're concerned about oiling, looking at Improved Racing for pan baffles and possibly an Accusump. We run their pan baffles, oil cooler attachment, and an Accsump for oil control and cooling on our car with the FBody pan.
Old May 11, 2017 | 05:01 PM
thunder57's Avatar
Car: 1987 IROC
Thanks for the input! I'm not looking to do anything crazy but want to make sure my 10g investment stays healthy.
Would you recommend the Crank Scraper as well?
Jake
Old May 11, 2017 | 05:06 PM
Beater79TA's Avatar
We didn't but they didn't have one at the time for the stroker crank we are using. If they make one, I can't think of a reason not to use it.
Old May 11, 2017 | 06:08 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Just be aware that the F-body oil pan has one of the smallest sump capacities of any LS engine (maybe the smallest?).
Old May 11, 2017 | 06:15 PM
Beater79TA's Avatar
While the pan may be the smallest sump, with the oil cooler and 2 qt accusump we have 12 qts in the system with 2 qts being pushed by the accusump whenever pressure drops below 25 psi. The accusump also provides a nice pre-lube when the key goes hot prior to starting the car
Old May 11, 2017 | 06:41 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That's a really good point and I'm glad you said that. My oil gets old really fast and I have to do oil changes VERY frequently. I should get off my butt and install an oil cooler because I think I need one big time.
Old May 12, 2017 | 10:47 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have the lines & fitting from my donor vehicle, but I haven't bothered because my oil stays nice & fresh in my stroker. Granted it's not in a 3rd gen, and just drag raced (as well as driven to/from the track). And I'm a synthetic oil junkie.
My '99 Silverado 5.3 has a cooler, not sure how needed it is. Suppose it doesn't hurt anything. And if you're abusing the car, a cooler is a good idea.
But now that I think about it, the 5.7 in the Camaro is a little harder on oil. I chocked it up to being a little longer in the tooth than the stroker and more street miles. Maybe it has something to do with the pan, smaller oil filter, and more cramped engine compartment.
