Third gen Ls swap harness to stock harness
Old Aug 10, 2017 | 12:10 PM
randallp504's Avatar
Car: 1983 Camaro Z/28
Engine: 305 HO
Transmission: 700r-4
Axle/Gears: stock
I'm not sure how to search it or what the name of it is, but a guy I talked to before getting all my swap parts together said it was a Lingenfer or sounded like that, adapter that connects the two. If not what is needed to be wired to my painless from my cars original wiring harness? It's a 1983 z28 btw. I've seen it in his car and everyone I search adapter to harness it brings up modules and harnesses. Any info will help. Thanks randy
Old Sep 15, 2017 | 11:50 AM
90' 305TBI's Avatar
Car: 1990 Camaro RS
Engine: 5.7
Transmission: 4l60e
Re: Third gen Ls swap harness to stock harness
Not entirely sure, but i havent came across any quick plug and plays for the ls swap harness to the stock harness. From what i understand you will still have to wire in the swap harness to the vehicle. Which is maybe 3 or 4 wires. VSS, Tach, P/N switch and fuel pump.
Old Sep 15, 2017 | 05:26 PM
Engine: 305 HO
Axle/Gears: stock
thanks for the reply. My car has the vss in line with the speedo cable at the trans but I'm not sure if my car even needs it, it's cable driven speedo, no cruise control.
Old Oct 21, 2017 | 12:17 PM
Pocket's Avatar
Car: 91 Trans Am
I offer 3rd gen to 98-02 Fbody adapter harnesses in addition to full PnP swap harnesses
