Vats problem
Old Sep 16, 2017 | 05:56 AM
Mattis's Avatar
Vats problem
1987 trans am GTA. 95 Lt1 9c1 engine, trans and pcm.
Turned off vats in Tunercat. Scaned for errorcodes in scan9495 and IT says vats stil is activated in pcm!
Any idé whay this is happening to me?
Old Sep 18, 2017 | 10:31 PM
Robbie8586's Avatar
Car: 1985 Camaro sport coupe
Engine: was 305H, 2002 Camaro LS1 now
Re: Vats problem
I used this and didn't code VATS out of the PCM. I hope I am not violating any rules by putting this link in. http://www.3rdbrakeflasher.com/gm-va...lt1-p-182.html It worked great for me. I put it on a fuse in the factory fuse box so I can remove the fuse to activate the VATS.
Old Sep 19, 2017 | 07:10 AM
Mattis's Avatar
Re: Vats problem
Ok Thanks. I Will try that!
