ecm mounting
Old Sep 25, 2017 | 08:27 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
ecm mounting
Where did you guys mount your ecm's? I probably would have to move mine & the fuseblock inside somewhere
Old Sep 26, 2017 | 01:24 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: ecm mounting
i was curious about this also, the trucks have them under the hood... i don't want to add any wiring to mine, i may mount it on the driver side just behind the headlight area, the cold air intake will be above it in that area.
Old Sep 26, 2017 | 09:09 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Re: ecm mounting
I did not want to add to mines either... I will try and mount it in the engine area also. Probably the space you indicated... I should be finished my harness this week... Hopefully everything installed/running by Thanksgiving...
Old Oct 9, 2017 | 01:02 PM
Billgluckman's Avatar
Re: ecm mounting
This is what I was thinking too. Air intake mounted directly over the pcm. Has anyone done this and have pics? I'm not sure if the wires will reach without adding.
Old Oct 21, 2017 | 12:12 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ecm mounting
PCM goes in the stock location. You can either got the stock route behind the fender or cut a hole under the HVAC box
Either reuse the factory fuseblock under the dash for EFI cars or build a small engine only fuseblock to mount under the hood for carb cars. No sense in making things overly complex
86iroc504
Sep 25, 2017 08:33 PM
