Ac on an 03 and up pcm?
Old Nov 8, 2017 | 12:08 PM
IROC-Turbo's Avatar
I was told the A/C request on the 03+ computers is a serial data signal from HVAC control module, no wire input to trigger ac.
What exactly does this mean?I want ac.
Old Nov 8, 2017 | 06:59 PM
johnw999's Avatar
Re: Ac on an 03 and up pcm?
I'm not an expert as to why A/C can't be controlled by a 58x ECM swap. Speartech doesn't offer it on their 58x harnesses, and they recommend vintage air. I kept the original 1984 design on my Trans Am. I added a vintage air trinary switch to replace the high pressure switch. The old style compressor had a high pressure switch. The sanden compressors do not.
Old Nov 8, 2017 | 07:45 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Need more info from you than just that you want A/C.
CANBUS (Serial Data) is used to integrate PIM, BCM, and ECM control functions.
What Johnw999 is describing, is a work-around which allows operation of A/C but is not ECM controlled. This could result in stall conditions at stop light, and has no high rpm cut-off protection. As long as you have a good memory and keep the operating conditions in mind, you can have functioning A/C this way. You could program a higher idle rpm to avoid stall, and remember not to high rev with A/C on (we all have excellent right foot control, here ).
Trinary switch monitors psi and will cut-off compressor according to high and low presets.
Old Nov 9, 2017 | 07:25 PM
IROC-Turbo's Avatar
58x?Relucter?Mine should be 24 as its a gen 3.
But sweet to know a work around.
Old Nov 14, 2017 | 07:51 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
https://www.thirdgen.org/forums/ltx-...reen-blue.html
This is everything you need to get ac working with the stock hvac controls, high pressure switch, and ecm.
