Quote:
not sure about the t56, i just put a 6.0 with a tremec tko in my camaro i am using a spohn cross memeber with loop, i will have to modify it for the exhaust most likely but will be looking to keep the loop.Originally Posted by johnw999
Has anyone installed a driveshaft loop behind the T56? With my LS swap, I think it's prudent to consider failures that can cause injury. Ergo my quicktime bellhousing. I know UMI offers a driveshaft loop with it's torque arm relocation mount, but I don't know if that will fit behind my T56. Thanks Spohn sells a trans cross member with a front hoop for the T56. BMR used to have a version of their torque arm that had a split rear hoop that unbolted for driveshaft removal, although I don't see them selling it anymore. Closest thing now is there xtreme torque arm kit which comes with a hoop you weld in.
Safest combination is to run them in both front and back locations, which then also minimizes body damage should any part of the driveshaft come apart.
I would also suggest removing your torque arm mount from the trans and relocate to the trans x member if your still shopping.
Spohn T56 front x member with hoop, combined with BMR Xtreme Track pac kit should get you there.
five7kid
close
I ran a Jegster on my 3rd gen LS1/T56 car. Fits nicely. Doesn't look like they carry it anymore, but do have this: http://www.jegs.com/i/Lakewood/620/18020/10002/-1 On sale right now, even.
