Bit confused.Trans location
Old Jun 1, 2018 | 07:46 PM
IROC-Turbo's Avatar
Keep getting conflicting info.
To use my original drive shaft do i need to change the trans crossmember?I keep reading the 4l60e is the same exact length.But i don't know if thhat means the ls 4l60e.
If there is a difference between 6 bolt tailhouseing 4l60e and the 700r4 and or the 4 bolt tail 4l60e,how much difference?
Old Jun 1, 2018 | 09:15 PM
Billgluckman's Avatar
Re: Bit confused.Trans location
The overall length is about the same. The 4l60 trans mount is located a little further back than the 700r4 mount so you'll need a swap crossmember or modify your factory crossmember.
Old Jun 4, 2018 | 08:07 PM
IROC-Turbo's Avatar
Thanks. If im correct its 1 3/32.
Steve86TA
Nov 24, 2006 08:02 AM
Steve86TA
Exterior Parts for Sale
Oct 29, 2006 02:12 PM
Steve86TA
Oct 29, 2006 02:10 PM
Steve86TA
Oct 29, 2006 02:08 PM
TravisZ28MAXX
South East Region
Nov 16, 2003 06:43 PM
