LT1 Low Resolution question....
Old Oct 9, 2019 | 08:28 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Gentlemen,
I've got an issue w/my LT1 that I'm trying to diagnose. To help me with my diagnosis, I'm using a "period correct" OTC Monitor 4000 scan tool. I took a recording while the car was doing the symptom and what I don't "get" is what the numbers represent, that are displayed under the "HiRes" and LoRes" displays? During the symptom, the Low Res signal only shows "002"....while the symptom is NOT happening, the Low Res shows a variety of numbers, constantly jumping all over the place.
Can someone shed light on what that number represents or means? Thanks.
Old Oct 9, 2019 | 08:31 PM
Engine: LT1, L400
Re: LT1 Low Resolution question....
EDIT: Here is a vid of me doing a frame by frame play back of the recording. You can see the:
RPM...HiRes...LoRes....TPS%
Codes.MAP....Left 02....Frame #
When I get to ^5000 RPM, the low res signal displays only "002" for the duration....
Old Oct 12, 2019 | 10:29 PM
Engine: LT1, L400
Anyone? Low Res "counts" (?) and what that number means?
Old Nov 15, 2019 | 02:46 PM
Engine: LT1, L400
This response has been overwhelming. :/
Are there no GM techs or any tuners who know what the Low Res "number" represents or tells us?
Old Nov 15, 2019 | 02:50 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
That happened to me once, turned out to be opti
transamws6
Theoretical and Street Racing
Jun 11, 2012 08:09 AM
Gallileo60
Sep 12, 2011 08:12 PM
chevyowner02
Aug 2, 2007 07:23 PM
Chrome.45
Feb 10, 2003 07:33 PM
89 Iroc Z
Feb 7, 2002 07:43 PM
