Update: Boze Wheels are on!
Old Mar 13, 2008 | 03:55 AM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
Today my new HID Headlights came in, I will provide a detailed installation if some of you guy's ever decide to go with HID's in the future...that will commence on monday.
I also went to the Tire Shop and picked up my Boze Rims where they had the Toyo T1-R's mounted, balanced ect! The tire sizes are 245/35/18 front & 285/35/18 rear...man are they wide compared to my old one's which were 225/45/17 front & 245/45/17 rear...you can see the difference in one of the pics. I also repainted the brake brackets, center part of the rotors (black) and the calipers (red)...I will upgrade to the Z-06 Calipers probably in the fall or next winter along with an air ride kit & tubular k-member/a-arms!
Here is what has to be done for the correct fitment of a 10" rim with a 6.25 backspacing on a 3rd gen Camaro...first you have to remove the bump stoppers, then you have to cut the inside of the fender which is shown to prevent the tire/rim from rubbing and then you have to massage/hammer the part where the rear seatbelts are held in place (down low where you see the red battery cable running)...mind you I removed mine outta there a while back because no one sits in the back anymore! and there you have it...not that much in modding for the big rims to fit nicely tucked in the fender well, I will post up more pics when the car is on the ground next week!
Old Mar 13, 2008 | 07:16 AM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: Update: Boze Wheels are on!
Im even more in love with your car now!
What do you want for your old TT's?
Old Mar 13, 2008 | 07:23 AM
Sinister Z's Avatar
They have been already sold...sorry!
Old Mar 13, 2008 | 07:55 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
what HID kit is that? the lenes look kinda coo ( i love my 4300 kit).....and the rest of the car looks amazing too
Old Mar 13, 2008 | 07:58 AM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
Rims look great!!!
As said before..where and what HID kit did you buy?
Old Mar 13, 2008 | 11:05 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I'm running 17x10 with 6.25 backspacing and I haven't removed my bumpstops. There isn't much clearance though. Were yours hitting or did you do it just to make sure?
Old Mar 13, 2008 | 11:25 AM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
We need pics of it on the ground to see how they tuck under the car!!
Old Mar 13, 2008 | 02:09 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Can't wait to see it on the ground!
Old Mar 13, 2008 | 02:21 PM
Sinister Z's Avatar
The kit is the XP4656 from here
http://www.brightheadlights.com
Yes mine were rubbing so I had no choice but to remove them + the car has already been lowered from '93
Those are coming
Last edited by Sinister Z; Mar 13, 2008 at 02:25 PM. Reason: Automerged Doublepost
Old Mar 13, 2008 | 04:05 PM
BADNBLK's Avatar
COTM Editor
I still don't understand why the bumpstop and mounting plate needed to be cut off. When that car is on the ground (especially lowered) that area that was removed would be closer to the axle tube where there is less chance of interferance. I had to "massage" my inner fender area near the LCA to ensure clearance on cornering with my set up.
Not hating, just not sure why
Old Mar 13, 2008 | 05:00 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I think you should have left the TT's on it, just my .02
Old Mar 13, 2008 | 05:47 PM
Demon355's Avatar
Those will look good Nik, lol @ Andy in there with a sawzall!
Old Mar 13, 2008 | 06:46 PM
Sinister Z's Avatar
I just got to work from the shop & the car was virtually done...the Headlights were all installed also...I'm like "WOW" when I walked in, I wasn't expecting it to be finished.
The pictures that I have already posted were basically the fitment pics...now everything is back in place and the car was down...it really looks slick, I will put up the pics of it tonight when I get home after work!
It's because of the offset on mine it was rubbing, you couldn't even get your finger in between the bump stop and tire & I also had to massage the lower inner fender by the LCA's.
Last edited by Sinister Z; Mar 13, 2008 at 06:49 PM. Reason: Automerged Doublepost
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
