Door side moldings...
Old Apr 11, 2009 | 05:41 PM
Stratocaster25's Avatar
Car: 1992 Z28
Engine: LB9 305
I have a 1992 Z28 and I need to replace the side molding on the passenger side door. I found a place online where I can get a replacement, but it doesn't list the color. Here's the link: http://www.parts.com/oemcatalog/inde...layCatalogid=0
I need number 4 in that picture. Should I assume that it comes only in white?
Old Apr 11, 2009 | 07:04 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Door side moldings...
getting a good color match with an aftermarket part is impossible( almost ) . anyway check with a good local body/paint shop and ask them . there are so many side moldings that were/are used that it's hard to give a good answer . good luck .
Old Apr 11, 2009 | 07:08 PM
deoverton's Avatar
Car: 1992 Camaro RS
I would figure that it would be the most body pieces that you buy and you have to have it painted your self to match but I really don't know. Try shooting them an email or calling.
Old Apr 11, 2009 | 08:02 PM
Car: 1992 Z28
Engine: LB9 305
I did notice that when you order it asks for your VIN number. I wonder if they'd use that to determine the color that you'd need?
Old Apr 11, 2009 | 08:21 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
As parts started to get older and stocks ran low, you got what you got, when you ordered a part from GM. It always seems you got whatever color you didn't want when you ordered. But the next time you ordered the same part you got the color you needed the last time. If you want to assume anything assume your going to need to get it painted to match. What you get could be painted, unpainted or primed for paint. But hey ... maybe it's your lucky day!
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
sonu1975
Aug 11, 2015 08:38 AM
