Need Help Fixing Blinkers
Hey Guys,
I am having trouble with my blinkers on my 1992 Camaro. When I turn them on the light on the dashboard doent flash on. But when I turn on the hazard lights, the lights turn on. I have tried changing the light bulb and check the fuze and they both seem ok. Do I need to replace the blinker switch?
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Need Help Fixing Blinkers
When Camaros are similar to Firebirds, you should have two separate relais behind your driver's side dash panel. You probably need to replace the one for the regular indicator function.
RedLeader289
May 28, 2019 01:47 PM
