My 84 Z28
Old Jul 29, 2016 | 10:26 PM
  #51
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: My 84 Z28
Govlock just like my 84. Did they ever put any other posi in 1984?
Old Jul 29, 2016 | 10:35 PM
  #52
gt4373's Avatar
Transmission: 5-Speed Manual
Re: My 84 Z28
Did You Remember To Add The Limited Slip Additive.
Old Jul 30, 2016 | 03:49 AM
  #53
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
GT the lube I got was Castrol brand and it said that it was for limited slip differentialso, so I used it as is. I hope that's okay...
Old Jul 31, 2016 | 03:05 PM
  #54
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Today I am changing the transmission fluid. Got it all drained and cleaned up. Fluid looked decent and didn't smell terrible. I saw lots of Dextron 6 fluid so I did some research on here to see if that's okay, and it appears to be acceptable so I'm off to wally world to pick up a jug.
Old Jul 31, 2016 | 03:06 PM
  #55
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Old Jul 31, 2016 | 03:08 PM
  #56
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Old Jul 31, 2016 | 03:12 PM
  #57
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
It's hard to see, but there's a bare wire, it looks like a ground, on the passenger side right behind the headlights. Possibly something looks like it was bolted on there maybe? Saxondale you have any ideas?
Old Jul 31, 2016 | 08:41 PM
  #58
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
Hmm. Not sure. Having a hard time identifying the photo location. I can check my car. Remind me if I forget. Focused on rust currently so quite preoccupied.
Old Aug 1, 2016 | 09:11 AM
  #59
gt4373's Avatar
Re: My 84 Z28
Is That Pic Taken From Behind The Battery,Take A Wider Pic So We Can Get A Better View.
Old Aug 1, 2016 | 05:48 PM
  #60
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
Looking at my car it is a ground wire leading to one of the harnesses in front of the radiator support and behind the headlights. It's likely for either parking light or headlights on that side. There is a similar single wire on the drivers side of radiator too, mounted to ground screw in same location. On passenger side there is a paired wire (like speaker wire pair) leading to one harness, and a single black to another part of the light harness.
On the drivers side, the cruise control ground is also connected to that screw.
I have photos. Will upload and share here.
I think it would be safe to add a loop connector and hook it up to that ground screw. Check your light operation in front, parking and headlight, before and after connection. Don't forget to try the brights.
Old Aug 1, 2016 | 06:03 PM
  #61
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
Last edited by Saxondale; Aug 1, 2016 at 07:06 PM. Reason: replaced mega pixeled photos with lower res download friendly.
Old Aug 1, 2016 | 08:46 PM
  #62
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Excellent, thanks! I'll check it out and report back to you...
Old Aug 1, 2016 | 08:50 PM
  #63
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: My 84 Z28
Originally Posted by Saxondale
Excellent reference photo. NOW I recognize the area. My T/A has the same holes / panel, but nothing bolted there. I wonder what was mounted there?
Old Aug 6, 2016 | 11:26 AM
  #64
reddawg's Avatar
Car: 89 Iroc Z28
Engine: 350 tpi
Transmission: 700 R4
Re: My 84 Z28
Solid car, 84! That thing looks mint..
Old Aug 6, 2016 | 06:28 PM
  #65
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Thanks Reddawg! You're probably looking at Saxondale's car... ours are very similar but his in better shape than mine....for now! LOL JK.
Old Aug 6, 2016 | 06:32 PM
  #66
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
I haven't been doing much on mine for a couple of days. I did drive it to work a couple days and it drove fine. the steering is still a little on the loose side, but i'm still working on that. I did receive my t top bag from HenryD3 and it is awesome. I also have a mirror trim panel for the drivers door on the way from another board moderator. today i'm building some stackable wood blocks out of 2x10's to get the car a couple of feet up off the ground. should make it easier to work under it.
Old Aug 6, 2016 | 08:13 PM
  #67
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
I expect your car will clean up in those underhood areas as well as mine. It took many hours of cleaning to get to that state, and there are many many more hours of detailing remaining in those photos alone. Top of the radiator support now has a gloss, but was no easy task by hand. Photos definitely show more filth than is apparent in person.
But as you know, getting the basics of car function consumes these initial days and years. Had mine a year now and thought I'd be much farther along. But I can see this car will take years to finish. Stay the course.
Old Aug 12, 2016 | 08:13 PM
  #68
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Well, tonight I had time to fix my drivers mirror control in the door. I got a replacement part from a member of the board, turned out to be a little different from the part that's on there, but it works and looks better. Then I took it out for a little 20 minute drive. It is a beautiful evening here since it's finally cooling off. Anywho....
No more hole where the mirror control is!
Old Aug 14, 2016 | 07:03 AM
  #69
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Yesterday I changed the engine oil and filter, and then my wife, daughter, grandson and I all went downtown and cruised and saw lots of cool cars. Had a great time. I also ordered a new GM brake pedal pad! Super exciting! Not. But it needs it as the one on there's worn nearly in half. I am going to clean up the engine bay area as well. I noticed last night that on the underside of the hood under the dirt and grease is nice shiny red paint! Lol.
I need to get a new hood insulation ordered as well
Old Aug 14, 2016 | 07:33 PM
  #70
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Spent a little bit of time under the hood today. My coolant overflow tank was filthy so I removed it and took it to the car wash and cleaned it up. Not perfect but much better. Cleaned the underside of the hood. At least a portion of it. Found a broken wire that goes to the light under the hood
I disassemble it and was going to try and solder it but it was not working. I guess I'll be looking for another.
Found a large ground wire not hooked to anything...Saxondale any ideas? That last wire i found that you helped me out on was a ground wire for my passenger side high beam headlight.
Old Aug 14, 2016 | 07:36 PM
  #71
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Nice and shiny under the grime! Need to get a new hood insulation ordered...
Old Aug 19, 2016 | 01:32 PM
  #72
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Got a notification that my brake pedal pad has been delivered. I wish it were something more exciting, but it is something. Lol
Old Aug 19, 2016 | 03:16 PM
  #73
irvan's Avatar
Car: 1989 IROC Z28
Re: My 84 Z28
This is how that ground wire is on my 83 Z28.
Old Aug 19, 2016 | 04:00 PM
  #74
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Awesome, thanks! I will get mine hooked back up!
Old Aug 19, 2016 | 04:06 PM
  #75
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
I ordered front and rear brake pads and a new hood insulation pad from Rick's Camaro. Looking forward to that. And tomorrow is cars and coffee!
Old Aug 19, 2016 | 06:49 PM
  #76
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
The old cracked one that kept sliding off...
Old Aug 19, 2016 | 06:51 PM
  #77
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
And the new one all installed. Was going to go for a drive tonight but it decided to rain.
Old Aug 20, 2016 | 03:16 PM
  #78
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Today I removed the passenger seat and cleaned up the carpet under it, and made $1.19 in the process! Lubed the rails so the seat slides back and forth better. The plastic parts around the rails were in decent shape with the exception of one, but I don't think that it even belongs there. So I think I need to look for another front piece. Took it out for a drive and discovered that the cruise control is working...I thought I broke it, but maybe it only works above a certain speed? Glad to see it functions regardless.
This is the broken one, but I don't think it is for the car anyways....
I need another one like this....
I need to find the piece that goes on the lever, it's missing.
Old Aug 21, 2016 | 12:28 AM
  #79
Citation X's Avatar
Car: 92 RS
Re: My 84 Z28
Check southwest salvage on west and pawnee. They have some stuff to pick through although it is getting slim. I pulled a whole set of gray 91-92 seats that had no tears and in really good shape for 150 along with seat belts and most of the interior plastics. To bad I had already reupholstered my seats. Like mine better now though.
Old Aug 25, 2016 | 07:53 PM
  #80
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Today in the mail I received my front brake pads and the hood insulation. But the best part was in was able to meet up with forum member Citation X and purchase a dash pad in very good condition for an extremely reasonable price! He has a real nice 92 RS that's really nice and clean!
Hood insulation
Front Brake pads
Old Aug 25, 2016 | 08:24 PM
  #81
1988 Iroc 5.7's Avatar
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
Re: My 84 Z28
How does that hood insulation look? Need some for my camaro.
Old Aug 25, 2016 | 09:22 PM
  #82
Citation X's Avatar
Car: 92 RS
Re: My 84 Z28
Thanks for the kind words. Hope the dash pad works until you can get a perfect one. I got to go check out my brakes from bigbrakeupgrade.com and all I can say is WOW. It's like Christmas for me hah.
Old Aug 26, 2016 | 02:50 AM
  #83
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
I'll get it out tonight and get some pictures
Old Aug 26, 2016 | 07:39 PM
  #84
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
New and the old. Overall im fairly happy with it. Seems to be inside out to me. Being the fiberglass side is facing out and tje finished side is against the hood. I tried it the first time opposite but then the holes didn't line up. In the end, one hole was off and I had to poke the retainer through the material.....but its better than it was.
Old Aug 26, 2016 | 07:41 PM
  #85
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
All done.
Old Aug 26, 2016 | 09:44 PM
  #86
Car: 1988 Iroc
Engine: 5.7 TPI
Re: My 84 Z28
Looks good! Was it about the same thickness as the original?
Old Aug 26, 2016 | 11:07 PM
  #87
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
i have same insulation yet to be installed. And yes is backwards from stock. I'll post more later when not on tiny iphone 5.
Old Aug 27, 2016 | 01:17 AM
  #88
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Thanks!
I think so, it's about 1/2 to 5/8" thick. And the retainers that came with it are pretty nice as well.
Old Aug 27, 2016 | 06:35 AM
  #89
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
The fasteners do match the factory size and appearance perfectly, minus the GM part number.
I contacted RePops when I initially received mine, and asked if they knew which side should be out. I said it was backwards from factory design.
He asked me to provide photos and the date on the box so they could pull all the upsidedown pads from inventory, and said he'd sent a replacement. I provided detailed photos and the manufacture date from the box.
They sent a replacedment pad, for a 70-81 Camaro. I emailed and left a voice message to let him know. He never returned my call or email, so I followed up a week later by phone to learn a pad was in the mail.
When it arrived it was an 82-83 CFI pad. I emailed again and left a voice message. RePops did not return my email or call, nor did they send another pad.
Based on your pad, it appears they are still selling upsidedown pads.
The CFI pad was also upsidedown, so maybe the fuzzy side is down for a reason. Does it protect the hood paint better? Does it create better air space within the pad? Is the fuzzy side down less likely to collect moisture between pad and hood? Are they being made incorrectly? It's not clear, but RePops never gave an explanation of what is correct.
Old Aug 27, 2016 | 11:05 AM
  #90
DynoDave43's Avatar
Re: My 84 Z28
There was a member here who was successful in getting one of the pad manufacturers to make his the right way (not upside down), but he had to request it. I'll have to hunt through my notes and see whoa that was. I hope it wasn't you, Saxondale.
Old Aug 27, 2016 | 01:35 PM
  #91
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
No. Wasn't me. I'll eventually get mine installed upsidedown. First need to touch up a minor surface rust spot. Some day I'll order a correct one, even if good 'ol RePops. But must be correct.
Old Aug 27, 2016 | 02:51 PM
  #92
gt4373's Avatar
Re: My 84 Z28
My OE Is Embossed And Also Has The 4 Access Holes In The Rear Center To Remove The Hood Ornament.
Old Aug 27, 2016 | 03:53 PM
  #93
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
I guess us thirdgenners will have to show more love (spend more money) for the non-IROCs before we get correct repro parts. The IROCs will get first round of most accurate parts. Maybe other years will follow. Don't even know if the IROCs have have correct repro insulation at this point.
Old Aug 27, 2016 | 04:22 PM
  #94
mucker15's Avatar
Car: 1989 Iroc 5.7 1969 Camaro 2010 SS
Re: My 84 Z28
love the early cars good luck with it
Old Aug 27, 2016 | 05:14 PM
  #95
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
Originally Posted by gt4373
Does Any Company Make These To OE Specs,OE's Were Embossed And Also Had 4 Access Holes In The Rear Center To Remove The Hood Ornament.
I wondered about those four holes. Now it makes sense.lol
Old Aug 27, 2016 | 07:18 PM
  #96
DynoDave43's Avatar
Re: My 84 Z28
Does Any Company Make These To OE Specs,OE's Were Embossed...
Not that I know of.
Old Apr 19, 2017 | 04:00 AM
  #97
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
It's been a while since any updates, the car sat in the garage all winter. Got the battery charged up and took it out for a drive. I finally got around to replacing all of my brake pads and also replaced both rear brake calipers. Still need to replace the whole ebrake cable. Took the car to meinike auto service for a brake fluid flush. Brakes are working great, but it just seems to me that the pedal travel is long. Maybe that's normal. I finally found what was causing the idle speed to be so high...there was a little lever or rod sticking on the passenger side of the carburetor. I sprayed it with some wd40 Teflon lube and it's been good now. Really enjoying driving it. Still lots of interior work to do. And get the rust spots fixed.
Old Apr 19, 2017 | 12:33 PM
  #98
Citation X's Avatar
Car: 92 RS
Re: My 84 Z28
Have some stuff on mine to get done(hopefully soon). Then we need to go on a cruise sometime.
Old Apr 20, 2017 | 11:10 AM
  #99
84Z28dude's Avatar
Car: 84 Z28
Transmission: auto
Re: My 84 Z28
heck yeah. the guy i got the car from invited me to a car show up in Hutch so i may go to that. right now i'm not sure what i'm doing....im thinking of selling the car to purchase another car....i haven't decided or driven the other car yet so i'll wait a little bit to see how it goes. but i've alway wanted a Corvette and this one i'm looking at may be a diamond in the rough so to speak...LOL. who knows. i'm not in a hurry and right now i'm enjoying driving it...
Old Apr 30, 2017 | 07:25 AM
  #100
Saxondale's Avatar
Car: 84 Z
Re: My 84 Z28
Thanks for the update. Fun to see the photos of this car again.
