My new 1992 B4C 1LE
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
Re: My new 1992 B4C 1LE
Well its in and running ....
link to vid below
https://drive.google.com/open?id=1E0...dwApZoo_gqS7qg
link to vid below
Engine: LB9 305
Thanks, its down right now, replacing the rear brake line I burned a hole in with some slag while welding in my sub frame connectors and Im replacing all the clutch hydraulics , and adding an astro steering shaft from a guy on here while I have mine out. then i gotta get it across the street to have the exhaust hooked up .
Engine: LB9 305
well from TX to Fla. and now back to N.C. its spent alot of time on the trailer, and in storage, and now Im up in Charlotte area and i rented a big *** 30x50 for cheap, so its home in one place until I can find some land and build my own shop.
Engine: LB9 305
Well I finally got off my *** and got the exhaust welded up, I bought some 3 inch stainless tubing and another 45 and welded it up myself. had to wrap the y pipe where it runs under the oil pan and starter, also rebuilt a 96 camaro LT1 gear redution starter and installed it, solved the hot start issue, found the magnesium vette covers where hitting the tall polylocs that came with my rockers,so I found a set of tall covers, got one installed and now the frigging rocker hits the inside of the new covers..I just cant win. Also installed a set of taylor under header plug wires,I knew I needed some now ones , I just reused the crappy stockers to get it running , runs alot better now . Just need to keep plugging away at the tune.
