Question about Camaro
Old Jul 5, 2017 | 08:12 PM
cadams's Avatar
Want a title? Post!
Can someone tell me if my 91 Camaro Z28 is a 1LE. It has the G80 and G92 RPO's, but has rear drums, steel drive shaft, and AC.
Vin number : 1G1FE2381ML174031
Would appreciate any input. Thanks
Old Jul 5, 2017 | 08:31 PM
Drew's Avatar
Re: Question about Camaro
You kind of answered your own question. To get the 1LE option you had to order G92 and delete the A/C. So no, not a 1LE.
The real easy test is to look at the front brakes. Rusty cast steel calipers are non-1LE. Bulky aluminum calipers with dual pistons are 1LE.
Old Jul 24, 2017 | 06:01 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If you got those 2 codes off the RPO sticker, 1LE would be listed on the same sticker, but with what you already posted, its not a 1LE car.
Old Jul 25, 2017 | 05:34 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
ummm. does the rpo sheet match the vin number?
Old Jul 25, 2017 | 06:35 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
The VIN you posted above is not in the Compnine database. Check to see if it is accurate, but it may be one of the few they are missing.
To answer your question though, no, it would not be a 1LE unless it was a B4C and even then it would be one of very few for 1991.
