its finally done!, over 3yrs in the making.......
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
have the TV cable adjusted as close as I can w/o line pressure gauges, carb seems to be dialed in, needs an alignment but I washed it for the 1st time tonight and snapped a few shots...
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Re: its finally done!, over 3yrs in the making.......
looks good, bold paint scheme and colors.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
From a neighbor in Rockford...nice car!
I have two project thirdgens myself...that won't be on the road this year ;(
Nice to see someone else making progress...it motivates me...
Car: 1991 Firebird
Engine: 3.1L V6
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Congrats man
Looks good.
BTW, they are never done. You think its done now, but you will find more stuff you want eventually
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Awesome race green color!
Car: 87 Camaro
Wow I love it! I have a green block too and you're the only other person I've ever seen with the same color block lol
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
f-ing amazing!!!! great job, like the neon green...something different
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
pretty sharp! let us know how it performs!
whats the specs on the engine?
Car: 82 Trans Am
Transmission: t-56
Thanks for all the love guys!
as for the questions, i'll try to answer all in one post.
The specs are a sbc 383, 13.1: compression, dart heads, quick fuel e85 converted Holley dp, tuned on power plus's dyno made 600.1 hp @ 6200rpm all forged internals, nasty custom cam, trans is VERY BUILT 7004 converter is 3200RPM stage 4 stall by revmax with all of their upgrades. c5 vette brakes up front, stock sized rear discs in back with wilwood calipers
all stainless braid.
rear end housing is a 10 bolt, that has been gusseted, strange axles, auburn 4.11's and aluminum girdle.
hood is from Glasstek
I designed the paint scheme myself taped out the design and my painter lay the paint.
as for the green, its a custom mix I call dominator green. we too a 50/50 mix of hok neon yellow and "planet green" , bottom is Orion silver (hok) and top is bc25 black
clear is Mercedes Benz factory "standox" clear
I am a powder coater, so obviously everything possible is coated, suspension etc...
my wonder bar, springs and calipers all match the green, everything else underneath is silver, gray or black
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
That is just bad a$$! I'm diggin the whole car. Great color choices, paint scheme, everything!
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
uh, DAYUM!!
that thing looks wicked!! makes me want to get kicken on my 83 even more, only issue is funds.
for some reason those wheel spats (in front of the rear wheel ferrings on the front) do something for a third gen unlike any other year. gives it that extra something. you did like i did, used te 85+ grid tails, i still have my orig tails so i can swap back and forth but the grids look great.
that thing looks wicked!! makes me want to get kicken on my 83 even more, only issue is funds.for some reason those wheel spats (in front of the rear wheel ferrings on the front) do something for a third gen unlike any other year. gives it that extra something. you did like i did, used te 85+ grid tails, i still have my orig tails so i can swap back and forth but the grids look great.
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
i'm sure that'll win you some trophies at shows. plus I love how you even matched the color of the engine block to the body. Great job!
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Very nice combination of colors. I like it.... Is that Kawasaki's 'racing' green color? Looks kind like the color of my ZX9R!
John C.
John C.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I'm impressed.... awesome job
so how are you going to feel when you see half a dozen birds that copy your ideas? I could see that happening.. you've got great lines on your paint.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Great looking car, nice paint!! Another E-85 guy, isn't it great to have decent compression in an engine again?? Been running it about 3 years now with great results. Excellent dyno numbers, too!
Car: 82 Trans Am
Transmission: t-56
Car: 82 Trans Am
Transmission: t-56
Was out with a few friend over last weekend, took a few photos:
Car: 82 Trans Am
Transmission: t-56
heres 3 from my buddies bad *** camera, several action shots coming too!
Car: '82 Camaro
Engine: 383
That is some really great camera work!!! What kind of camera is your bud using anyway???
Profile and stance on your car is absolutely perfect!
Wow, 600 horse 383! Not only looks badass, but has the ***** to back it up.
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Congrats on the completion of your car, I like the paint scheme and how you laid it out because it compliments the lines of the car. IMO though a 2" cowl would look way better, the 4" looks awkward on a 3rd gen.
Car: 82 Trans Am
Transmission: t-56
to get the stance I wanted I went through several sets of springs.
I started with moog replacement ws6 springs, didnt like the height (looked like a 4x4)
then went to eibach prokit (iirc) which is the higher of the 2 sets, then still wasnt low enough so I removed the rubber isolators above the springs in the front and left the rears, This achieved the subtle "rake" I wanted, then went to other set of eibachs as it still wasnt low enough.
I powder coated the springs the same green as the paint and now its right where I want it.
wheels are 17x9.5 in the back with 275/40's and the fronts are 17x8.5 with 245/45's. I think I want to go up one size in wheel to 18's this winter, but looking to keep a similar wheel design
Car: 82 Trans Am
Transmission: t-56
yeah the hood is a bit taller than I would have liked, however the 4" is actually needed to clear the air cleaner (and thats with a drop base too)
funny thing is I originally planned for a 6" air filter as well
Car: 1994 Trans Am
Im happy for you man. 3 years is a long time. I Wasnt digging it a week ago when I first read this post, now I am. The giant black cowl looks like a dorsal fin on a silver shark in those side shots. Just awesome!
Car: '85 Z28
I really like the little bump in the paint line at the B pillar. Nice touch!
Car: 82 Trans Am
Transmission: t-56
well, been a while since I posted this, but like mentioned by a member above, it is never done!, the 10bolt died on me 2x and I snapped a ds and a u joint, so out they went and a nice ford 9" went in. went with a Detroit locker, and 3.70 gears to be more street friendly. Capped the rear off with 98+ f-body FRONT rotors and 4 psiton wilwoods to squeeze them the auto trans held up fine, but wasnt fun on the street so out that went as well in favor of a nice little t-56 and CF billet flywheel and 6 puck ceramic clutch. Being am '82 I had mechanical gauges so if I wanted a speedo to work, I needed to do more work, I decided on some custom gauges from speed hut, replacing both the tach and speedo, with them working on replacements for the other gauges to be available in the next few weeks.
Latest project is my 19x11 vette wheel score off tirerack.com. bought 4 hoping there was a reasonable way to stuff a 19x11 under the front, but that was a no go, so off 2 were sent this week to Eric Vaughn machine in cali to be narrowed down to a more reasonable 8.5", the rears however will stay 11" wide and will be wrapped in the new 305/30/19 Pilot sports I scored off ebay. To stuff the 11" rears I and doing some slight "tubbing" if you will and should be able to finish that up before snow flies ( I hope) Lastly, my 98+ front brake conversion will be upgraded to now having 14" rotors and similar wilwood clampers I am running on the rear but maybe in the 6 piston variety.
well thats it for now
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
hes got his own shop IIRC..remember seeing your bird on RKC a while ago
nice build
Car: 82 Trans Am
Transmission: t-56
Sorry guys been offline for a bit, (3rd daughter coming in a few weeks lots of house prep)
Added 08 replica black c619x11 rims all around, had a pair narrowed to 19x9 to fit the front to answer above, I used to own a powder coat shop but the project started well before and us still going.
Thanks for the love, have a super Christmas.
