Brisk
close
- Join DateJul 2004
- LocationBeautiful BC
- iTrader Positive Feedback96
- iTrader Feedback Score(25)
- Car'88 IROC-Z / '91 Z28 / '91 GTA
- EngineLT4 Hot Cam 305 / L98 355 / MR 383
- Transmission5-spd / 700R4 / 700R4
- Axle/Gears3:45 / 3:23 / 3:23
- Liked:0 Times in 0 Posts
Picked this car up from the original owner who is also a board member. '91 GTA L98 700R4, appears to be a fully loaded hard top car (I have still not ran the RPO codes). Car came equiped with ported aluminum heads, 1.6 roller rockers, Crane cam, miniram intake, headers and full exhuast, etc. etc. The car is in really great shape inside and out, virtually no rust, and has been stored in a garage and not winter driven.
The bad news is the car has an engine knock under load, a light ticking which sounds like a wrist pin to me. The previous owner rebuilt the top end thinking that was the problem but apparently that was not the case. The hood was not on the car when I picked it up and the first thing I did when I got it home was to remove the bra it had installed on it. The hood is now on, but it needs a little bit of adjustment to close up the front gap.
I had no intention on purchasing another third gen, but this one fell into my lap and I couldn't resist. It needs a good polish and wax, and a good interior cleaning and vacuum, but it is pretty clean as is. Here is some pictures, let me know what you think!
Brisk
close
- Join DateJul 2004
here are a few more pictures;
thats really really clean, how muchdid you get it for
COTM Editor
BADNBLK
COTM Editor
close
Nice! Totally jealous of your deal!
Clean. Is that an LT1 intake?
i think its an lt1 in general
I think you should sell me the tail lights....hahahaha j/k. Awsome clean car you got. Thats a TPIS Mini Ram Intake. Im deciding between that & a HSR setup.
i have to get knowledgable about all the tpi setups they have. and are those stock 91 tails, i dont ever remember seeing the red bar across the top, or maybe ive always overlooked it
Brisk
close
- Join DateJul 2004
Quote:
its the original L98 motor with a TPIS MiniRam intake and aluminum heads, etc.Originally Posted by tylercamaro
i think its an lt1 in general blacksunshine'91
close
Quote:
Those are the stock lights for the '91-'92s. Earlier years have the red reflective bar across the bottom. Its the prime reason lights from those two years are so expensive.Originally Posted by tylercamaro
are those stock 91 tails, i dont ever remember seeing the red bar across the top, or maybe ive always overlooked it Brisk
close
- Join DateJul 2004
Quote:
ok well it is probably a good thing this car has been garage kept. I'll clean up those tails, coat them up with some protective polish, and keep them out of the direct sun and reduce them to any unnessessary expose when I'm not out tearing up the asphalt!Originally Posted by blacksunshine'91
Those are the stock lights for the '91-'92s. Earlier years have the red reflective bar across the bottom. Its the prime reason lights from those two years are so expensive. Supreme Member
When you get her running well, let me know how that TPIS Mini Ram does. Im torn between that & the HSR. I might get both since i have 2 TPI cars. All depwnds on the cash flow.
Nice ride Brisk! And the cupholders on the doors are intact too! Not something you see often haha. As for the RPO codes, just punch in your VIN into compnine and it'll tell you what that thing's got. Do you have disks in the rear?
nice! I hope another one doesn't fall into my lap like that, I don't know if I could resist.
maks10
close
- Join DateJul 2009
- LocationMorgantown, WV
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1990 Trans Am
- Engine5.7 350 HSR afr195 xfi268
- TransmissionT5
- Axle/Gears3.08 posi
- Liked:103 Times in 71 Posts
Real nice!!!! Engine knocking??? Any ideas??? Ticking noise makes me think header gasket.Member
Wow, that's a beautiful car. Looks like a cleaner version of mine.
Brisk
close
- Join DateJul 2004
took it for a short drive to the gas station and back and the light ticking turning into a chest thumping 'bang bang bang' once the engine came up to temperature... so it is more then a wrist pin, probably a crank bearing or something similar, definately in the bottom end.
Fix her up, rebuild the bottom end.
ill buy it from you if you dont want it, nice example of an origial gta, pull the motor and put bearings in it, then beat the hell out of it.
Brisk
close
- Join DateJul 2004
I bought it knowing it had a knock in the bottom end with full intention of repairing/replacing the engine. I'm currently working on getting my '91Z put back together with a fresh 383TPI and I will have to finish that before I can start work on this car because I just don't have room to do them both at once.
I am debating right now on whether I should stick in a rebuilt 350 I have and drive it that way for the time being, or pull the stock motor, repair it, and then drive it...
Well for now I'd just have the GTA as a burnout/abuse toy... considering that the engine is screwed either way.
Brisk
close
- Join DateJul 2004
it won't take any abuse without the fear of it throwing a hole into the block, something I'd rather not happen.. no sense wrecking a perfectly good numbers matching motor.
I say swap top half of the 2 motors.
Brisk, you have one of my favorite set of cars... Awesome camaro's, and now a 91 trans am? Sweet! I plan to stop my collection with a C4 vette, and an Ls1 91-92 Formula, GTA, or z28...
Quote:
Yeah good idea, and I just noticed that the car must be extra-rare where you're from.Originally Posted by Brisk
it won't take any abuse without the fear of it throwing a hole into the block, something I'd rather not happen.. no sense wrecking a perfectly good numbers matching motor. Senior Member
Oh! youre the one with the kick *** tailights i love! haha. I posted like 3 threads about your cars Tail lights
carlos64030
close
- Join DateJun 2008
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1991 Trans Am GTA
- Liked:55 Times in 27 Posts
Beautiful! The '91-'92 Trans Am GTA is the most gorgeous out of all the generations!
You know youre not truly "cool" on the forums yet. If you trade me tail lights,ill make you the coolest guy on the forum! Cmon! Cmon!!
carlos64030
close
- Join DateJun 2008
LOL! I'm currently looking for some spare tail lights to tuck away in the garage, just in case.
