Help!
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
No, unless it was a police package car which are quite rare. If it is, it will be a tpi 350 car, with dual piston front brakes, and a bunch of other goodies. It will be an automatic, too. Look for the code B4C in the option tag inside the console, and the 8th character of the vin will be an "8". Most likely on the car in question it will be an "e" which denotes a 305 tbi motor. Also available was the v6 motor. Externally it's pretty obvious wether an RS is a v6 or v8 car, the v6 cars had the 15x7 inch early Z28 style wheels, whereas the v8 cars had the 16x8 flat late Z28 style wheels. (Stock, anyways.
) Let us hear how it goes. Hope this helps, and good luck!
