Thanks NastyL98_T/A!
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
Thanks to Tony we got my vette screaming now! we played with timing and it's bumped up to 10-12 degrees. got a base time but the damn dampner was greasy and only seen 1 of the marks with a flash light. so Tony and i took that for the base time and bumped it up some. no pinging at all and at a 10 mph roll she wants to break the rear tires loose on a WOT romp! 20 more hp or so i think she will
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
timing helps alot on our TPI motors. mine was set at 3*BTDC when i bought it, and just by bumping it up to 9*BTDC i gained 2 tenths and 2mph
Originally posted by MdFormula350
nice, u have ur own mechanic now
no more bog at low rpm and low mph! on a slow roll punch around 5-10 mph starts to break loose the tires but not completely. tonight i brought her out to school and with the dryer air man dropping the hammer at 65-75 mph in 2nd gear is getting somewhat violent!
I like Violence
doing an oil change sat and putting my front Y pipe on and i hope i do pick up a few tenths. better yet i hope i can hook the car at the track cause i think i need some DR's now especially when i do get a stall converter
next mod will be a high flow cat from www.exoticmuscle.com for 150 bucks
then all i need is a rear Y pipe and my exhaust will be done less long tube headers. our L98 have crap shorty headers but they are atleast headers and not manifolds. Longtubes are expensive! i think i'll wait on them
man with the dryer air i took her to school tonight so i could play alittle when i got out. definetly no more bog at all! i am so happy
well lets get onto it.....
i can definetly hear the rear wheels spin over on the 5-10 mph punch. at idle in park or neutral i sat at school and just listened to her. jabbing the throttle from dead idle 600 rpm to 2000-2500 rpm it is real crisp with no bog. i thought the bog was from a rich factor that these cars have. launches are more consistent and real hard! i stopped on a back road and stalled out maybe 1100 rpm and let her rip. WOWSA! those 285/40/17's with the 2.59 rear gear lit the *^&$ up! seen average of 4700 rpm with a spike of 1 yellow bar around 5100 rpm then backed back down to around 4700 rpm and finally hooked. when she hooked i immediatly slapped into 2nd gear and she bit hard with a nice loud chirp at 4900 rpm.
sheez she is starting to come alive.....Alive i tells'ya!
well lets get onto it.....i can definetly hear the rear wheels spin over on the 5-10 mph punch. at idle in park or neutral i sat at school and just listened to her. jabbing the throttle from dead idle 600 rpm to 2000-2500 rpm it is real crisp with no bog. i thought the bog was from a rich factor that these cars have. launches are more consistent and real hard! i stopped on a back road and stalled out maybe 1100 rpm and let her rip. WOWSA! those 285/40/17's with the 2.59 rear gear lit the *^&$ up! seen average of 4700 rpm with a spike of 1 yellow bar around 5100 rpm then backed back down to around 4700 rpm and finally hooked. when she hooked i immediatly slapped into 2nd gear and she bit hard with a nice loud chirp at 4900 rpm.
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Originally posted by Mad-Mic
LMAO... nah it's not like that man. it's about gearheads helping eachother! might be a time he will need me to pull a motor or build a computer or run wireless through out the house
I like Violence
I like Violence
It's funny you say that Mic. I will need some help this weekend pulling my motor out. Seems that my rings have gone bad already.
Originally posted by NastyL98_T/A
No prob man. It was fun. Damn balancer had no marks so the timing was set the "*******" way. Bump it up a little, drive it. A little more, drive it. Uh oh! I hear knock, back it off some! lol.
BTW i put that new front Y pipe on with no pre-cats and uht uhm gutted the main cat till i get my hi-flow cat installed. man she wants to rip now! from a 5 mph roll racing a blue dodge ram with the stripes and exhaust wanted to play cause i could hear him rev up going down the road so we hit a light and it just turned green when we got there and we both were still rolling and i nailed it and she spun up to around 3500 rpm on the roll and laid posi marks for a good 50+ feet when i hit second he was around 8 cars errr truck lengths back
after we turned around he got next to me and asked what year it was and i said an 87 he said he usually beats the ones that are before the LT-1's i said you never ran a low to mid 13 sec TPI vette that was tuned properly and hammered it again
Engine: LB9/383
Hey Mic, motor is coming out on Saturday. Will be using the shop so I have a lift
Gimme a call friday night on my cell. 443 668 3361
Gimme a call friday night on my cell. 443 668 3361 Thread Starter
gotcha! i'll be going to the track friday and then sat taking g/f to dmv for driving test at 9 am after that i am free. i might take a microsoft test directly aftwards which will take an hour or so and after that maybe around noon i can come over and help ya out.
i'll call ya maybe i can switch the test time to later in the day.
Engine: LB9/383
That works out perfect Mic! I plan on starting around noon, have the motor out by 3 and a bare block on the stand by 7
. Plus the shop is only a 1/2 mile from the MVA
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Not blowed up yet... its questionable when its gonna go.
Any wagers???
Any wagers???
Car: 1991 Camaro RS
Originally posted by Z28z
Let Aaron drive it. Then I'll put some money down.
ES87iroc
Mid-Atlantic Region
76
Oct 17, 2004 08:40 PM
ES87iroc
Mid-Atlantic Region
18
Aug 7, 2004 12:23 AM
