T56 Swap
Car: Pair of 92 Z28s
T56 Swap
If anyone would like to "join in the fun" next weekend Kris and I will be putting a T56 6 speed transmission in my car. Ya...so let me know.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Stevo and I got the 700R4 out Sat. Not to bad for 2 guys with hand tools and the car on jackstands. Now for the install, hope that goes as smoothly.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
have fun bench pressing the trans. btw i suggest u put the clutch and bell on the motor before you try to get the trans up there.
I think a floor jack will beat bench pressing the tranny. I know the clutch is already on, Stevo did his research, but thanks for the tips anyways.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hang the pedals yet? Thats a ton of fun!
Are you guys going to get this car put back together in time for the nats/picnic next weekend?
Car: 2000 Trans Am
Axle/Gears: 2.73 posi
ya itll be done...i think
ill update when its finished hopefully sat or sun night.
ill send you my payment when i get home though i forgot
edit - god damnint...not my computer
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Cool, I hope you get it put back together in time! I have yet to see your car in person. Steve and I swapped the manual into my car, shoot a pm if you hit a bump in the road.
No, not going good, a guy bailed who was gonna help. I dont have the right tools i need and everytime i start working on the damn car something goes wrong. Dont know whats up now, maybe taking off work wednesday to try and get it done...i dont know what to do at this point.
Car: 1988 DEI IROC Camaro
Engine: 5.7
Transmission: Viper Spec T56
Re: T56 Swap
I am about to do the same thing. What is the deal with how the hydro goes on - is the a U bolt i need to get? What do you need to do with the pedals to get the 4th gen pedals installed? thanks
Car: '88 IROC-Z medium orange metallic
Re: T56 Swap
Holy resurrected post Batman!!
You need to drill a hole for the master cylinder and two holes for the bolts. You can use a factory u-bolt or you can use two regular 3/8 bolts. Be sure to use lock washers and it's not a bad idea to use a little blue loctite. Mock up the pedals, mark the holes, remove the pedals, drill the holes then install them permanently.
1992 Trans Am
Aug 8, 2015 08:16 PM
