Help with Hyd. Clutch (LS1 T56)
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Anyone up for helping me with a clutch install on a LS1 T56. I have never done one before.
Car: 1984 TA
Engine: 355 SBC Mild cam.
Transmission: 5 speed
Axle/Gears: Stock
Re: Help with Hyd. Clutch (LS1 T56)
I will lend a hand if you find someone that knew what to do to install it. I need help with mine too.
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
They are fairly straight forward to replace, as long as you have a basic idea how to remove the trans. I used a regular floor jack but try getting a trans jack or I think they make an attachment for a regular floor jack, it will make it easier to keep the trans on the jack with the bigger surface.
