help, my trans is on its last legs, its making weird noises and rebuilding wont help because the case is bad. i need a T5 WC trans pretty badly. i probably have a month or two on this trans before i explode it. the trans doesnt have to be in perfect condition as long as its rebuildable. hopefully someone has one laying around. i also have a bunch of parts for an 89 iroc, and a complete v6 drivetrain.
Sorry to hear of the trans issue. I, unfortunately do not have any transmissions of any sort lying around. I was inquiring about the 89 iroc parts you have. What parts are we talking about?
Chris
Chris
were talking everything under the hood except the engine, exhaust manis, wiper motor, clutch/ pressure plate, shifter, bell housing, starter, starter bolts, cruise control, heater control, ac lines, whats left of a wiring harness, thats all i can think of right now.
How about the ECm and the wiring harness to the TPS?
Chris
Chris
let me revise that last statement, i used the ecm and most of the connectors for my swap. actually i dont have much left in the way of a harness, sorry for misleading.
No biggie. Just figured if you had it lying around.........
Chris
Chris
