Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Superram, DFI, Trickflow, Boyds, Seats and clutch
Old Jun 9, 2004 | 08:56 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I am completely changing the top end of my camaro so I will be selling the following parts: Superram (ported and polished) Edelbrock highflow intake (ported and polished to felpro 1205) TPIS 52 mm throttlebody w/ TPIS airfoil, IAC motor, & TPS Fuel rails w/ 30 lb injectors and accel regulator Misc (1 bar map sensor, all of the mounting hardware, bolts and 3 sets of gaskets) I have changed all of the lid bolts over to stainless button head cap screws This superram has been modified for faster removal (the inboard runner bolts go through the plenum instead of up from the bottom). I can remove the entire intake in 2 hrs. I am also sell the accel dfi gen VI, fasttrack adapter harness so it will plug directly into the stock 3rd gen harness. I also have the harness so the dfi will control torque convertor lock up and a separate harness to convert the 86-89 mas harness to a map harness. I have 3 different tuning manuals, the 6.32 tuning software, and cable. I will also include a panasonic toughbook laptop. The heads are trickflow twisted wedge gen 1 heads they have been ported and polished and gasket matched to felpro 1205. They have pbm spring and titanium retainers. I will include the AFR hydrarev kit with the heads. These heads have had a new three angle valve job and new valve seals installed in the last 3000 miles.
There are a few odds and ends that I probably forgot I will take $3500 for the whole lot of parts. I have over $6500 in all of these parts. I will seperate the parts into smaller lots if you are looking for just specific parts. I am asking $1300 for the superram, $1100 for the dfi and laptop and $1200 for the heads. The superram has been removed from my car and is ready to be shipped. I also have a set of boyd wheels 16x8 w/ BFGoodrich tires for $400. A complete set of gray seats and door panels from a 87 IROC that are in great condition $250. Flywheel, pressure plate, throwout bearing, master cylinder and all of the bolts for a t56 has 8000 miles on them $100. I can get pictures of any of the parts if needed.
Hotrodboba400
Dec 10, 2019 07:07 PM
e3pres
Sep 9, 2015 01:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
