Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Arrrrr!!!
Old Jun 12, 2004 | 02:13 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Arrrrr!!!
I cant get my headers in my car do you have to put a camaro on a lift to get full lenght headers in?
Old Jun 12, 2004 | 08:43 PM
Thirdgen86TA's Avatar
Re: Arrrrr!!!
Lemme guess... Hooker Long Tubes?
I just did a pair on mine. PITA
Old Jun 12, 2004 | 09:48 PM
pskel350's Avatar
Re: Arrrrr!!!
no but it sure helps
you will need atleast a pair of jackstands
Old Jun 13, 2004 | 12:19 PM
loud91rs's Avatar
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
the easiest way is to probably lift the engine a little bit, i think the pass. one will go in semi easy but obviously the driver u'll have to get some more room. fortunately i did mine when i dropped my engine in. good luck.
Old Jun 13, 2004 | 02:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you can slide them both in from underneath no problem. don't forget to remove the starter, and purchasing a mini-starter will negate the problem of pulling headers when it dies as well.
Old Jun 13, 2004 | 03:02 PM
Kandied91z's Avatar
mini starter and tubular k-member would definately be nice in your future....but yes a lift or stands at least will greatly reduce your stress. a major pita.
