Those in MN...
Car: 89 Iroc
Engine: 305TPI
Those in MN...
Do any of you know where I could get a set of chrome 10 spoke wheels stripped/sand blasted and maybe refinished? I have a set sitting in my garage that I bought for really cheap but they are peeling and I need to get it taken care of. I am wanting to go with some BIG brakes and my 15" IROC wheels will just not cut it. Also what do you think it would cost? Thanks.
Car: 88 IROC
Transmission: 5 speed
Axle/Gears: G92
If you have a set now that needs refinishing any plating shop should be able to strip and rechrome them. If you want a smooth finish you don't want to sand blast them as they will have a rough textured finish that will need to be repolished for chrome. Superior Plating in MPLS is a big shop and should have the ability to do this, or try Kens Plating in North Mpls. He is a small 2-3 man shop that does speciallty plating and vintage restoration. Both phone numbers are in the Mpls business pages. I have no clue what this type of work costs anymore, as I have been away from the plating end of a machine shop for some time now. Give them a call and you should get a good idea what you are looking at for cost. Good Luck !!
