Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Need help building up my 91 camaro
Old Nov 19, 2005 | 09:14 PM
stinger9000's Avatar
Since this is my first Camaro, I need some advice on what components to purchase for my car. If your near the Dixon area, email me at chrisjenni@grics.net. It would be great if you stopped by to check it out.
My future plan is to swap the 305 for a 350 so if you have the knowledge or experience that would same me A LOT of headaches. Also, info on rear ends, transmissions etc would be great to.
Old Nov 20, 2005 | 09:21 AM
MikeC.86Roc's Avatar
Where is Dixon?
I have done the 305 to 350 swap. Nothing to it, just a few details that we'd be glad to help you with.
I am assuming your 91 model is a TPI with speed density setup? MAP sensor?
If so, then most of what you need to swap will be the injectors and the EPROM in the ECU.
You might consider going to a 255 liter per hour fuel pump as well.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
86camaroman201
Aug 19, 2015 04:52 PM
GVMV
Aug 16, 2015 08:01 PM
sreZ28
Aug 14, 2015 07:48 PM
