Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
looking for a shop
Old Jul 24, 2006 | 01:57 AM
fbodyguy86's Avatar
Car: 92 camaro rs
looking for a shop
im looking for a shop int he milwaukee area to help me get mycar going. ive been racking my brain for like a month now and still cant get the car to start. i converted it from TBI to TPI and now i can get the injectors to pulse i replaced the
ECM
ignition control module
and the pickup coil
still not pulsing the injectors
tried to bypass the vats and still wouldnt start. ive just given up and am going to take it to a shop if i can find one close by that wont rape on labor
thanks
Old Jul 26, 2006 | 01:14 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
first; check for a vacuum leak, spray some carbuerator cleaner around the seams of the intake,o2 sensor and other seams, listen for changes in rpm. if there are any, it's an intake leak. make sure the cleaner you choose is sensor safe.
second;post back
Eric B
Old Jul 26, 2006 | 11:52 PM
fbodyguy86's Avatar
Car: 92 camaro rs
i cant get it to start to check for a vaccum leak it wont fire the fuel injectors it will run for like 2 secs if i spray starting fluid in it. im getting spark and fuel to the rail i have 40psi of fuel pressure. im not getting signal to the injectors. i tried to bypass the vats it still wont start i replaced the ignition control module, magnetic pickup, and the ecm. so i wanted to take it in i just cant come up with anything else on it
thanks
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
