Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
TPI adjusted.
Old May 30, 2011 | 01:59 PM
kpthook1012's Avatar
TPI adjusted.
I had a guy install a longblock in my GTA, my block was cracked. Now that He's done he can't seem to get the TPI adjusted right. Anyone in St. Louis interested in helping me out? My mechanic is sure everything is hooked up correctly, he's just not familiar with TPI. The car is idling like crap but smooths out around 2000 RPM. I sent him a link to adjust the TPS and he said it helped a little. He tells me the car needs to be hooked up to a computer to adjust the TPI. Any thoughts?
Old Jun 6, 2011 | 09:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: TPI adjusted.
if its idling bad but smooths out around 2k. he might have a vacuum leak or plug wires are on wrong or arcing. get a vacuum gauge it will tell you so much
Frozer!!!
Jan 19, 2024 04:55 PM
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
