My '91 RS
Engine: 3.1 V6
Axle/Gears: No idea
My '91 RS
hey guys, just wanted to drop by and post pics of the Camaro I got some months ago. I don't believe the rust is too bad. has a hole on the driver side floor pan, passenger side floor pan is rusted, some surface rust on the wheel wells, and some surface rust on the underside. paint is fairly decent, just some surface rust by the ttop area, clear coat is peeling, and like 3 "damaged " areas. the chassis(?) behind the passenger seat is bent. don't know how. ill post some of the interior later on today.
Car: 85 IROC Z28
Transmission: TH700-R4
Axle/Gears: 3.42 Rear Gear
Re: My '91 RS
Lookin good man! I see you got the T-Tops, and the 91/92 GFX on that bad boy.
Throw the Aero High-Rise Spoiler on that bad-boy!
Any leaks in the T-Tops?
Lets cruise once it gets a bit warmer.
Engine: 3.1 V6
Axle/Gears: No idea
Re: My '91 RS
Doesn't really leak. But the ttops are the plastic ones and are all cracked from the sun. As well the weather stripping. Right now I'm trying to remove tint with plastic bag. It's purple and I want some Astra Hammond louvers.
