85 Chgo area-door/emissions parts-60402 pickup
Car: 85 Camaro /65 Lemans
Engine: 305 vin H / 396-375 hp (Real)
Transmission: 700R4 / 4sp
Axle/Gears: 3.08 posi / 4.88 posi
Hi all - 1st time on mid-west
I hope this is ok to post-I read the guildelines and I think it's ok and you will move to classifieds in 5 days? correct me if I'm wrong pls.
1. I have 2 door inerds, excluding control switch which he had cut off from 2 doors i purchased to replace my rusted out shells- I used all the inerds including manual crank from my original doors. These are for power window and locks and still have motors attached to the regulators. No idea if they work.
2. I also have 2 door windows from these which have 1 & 3 sliver type chips (no cracks) at the top 1/4" or less of the glass, which I'm asking if these are wanted and saleable or I should trash.
3. I removed all emissions and have most of this stuff, computer, wiring harness (minus some of the accordion covering which I used on my remaining wiring and various rusted brackets and whatevers hanging on them. Thermostat housing, etc. Not the plugs under the dash as I don't want to mess with that. I would say it's working as there weren't any dash lights flashing and car ran pretty good with the computer, but was a spaggetti mess under the hood
4. I also have the carb, but I removed the throttle arm and put it on thee non-computer q-jet I had to accommodate the TV cable.
5. I have the cruise control stuff as I also removed due to rust and don't plan to work on and try to reinstall.
The rest I refurbished and reinstalled due to the hi price of restoration parts.
If interested in any of this, make me a fair offer and pick-up and review of the usability of this stuff before purchase is my desire, although shipping of "light" stuff is a possibility. Also, pls let me know YOUR OPINION if you read this, if none of this is saleable or wanted because I hate to toss stuff out someone else may need.
Finally, I need a few items someone may have,
1. a good drivers door manual regulator,
2. drivers seat triangle (original gray) that holds the seat belt
3. maybe a tci 700r4 lockup kit
thanks
tom 1985 sport vinH
thanks
tom 1985 sport vinH
