(3rdgen - 4thgen) parts cataloged with prices, easier to read, must sell
Old Sep 27, 2006 | 06:17 PM
Parts4sale's Avatar
will add more info and pic if interested in a part(s)
3rdgen IROC CAMARO SHELL $100
4thgen z28 CAMARO SHELL $100
programing / burning
4, 32k chips, g2 board, zip locker, pocket programer, software and manuals $200
mis stuff
1970 350 block, 1985 305 block, 2 cranks and sets of pistons and rods $50
416 casting 305 H.O Heads $25
infinity beta digital 300 "1000watt amp" $200
SVT Cobra mustang M112 blower 5k miles $750
Lincon mark 8 LSC dual catback exhaust with tips $50
94 mustang dash, back seat and center console $10
free
3rdgen IROC Smog parts
4thgen 96 trans am front hood part
3rdgen IROC fuel lines
beat up iroc hood no blisters
3rdgen parts more maybe added
3rdgen
engine / drivetrain / air / fuel
3rdgen Fresh 350ci 5.7 engine less then
25k miles on the the block, everything has been check by an engine builder I.E (block, crank, rods, pistons) flawless!! but new rings and bearings where added anyway, the engine came out of a 1999 Cadillac Escalade that was in a roll over its the same block as the ZZ4 but a non 4 bolt main, it still has the factory cross hatches in the bores,
CASTING#.....SIZE...YEAR...MAIN CAP BOLTS....NOTES
10243880...350...95-00...2 or 4...Vortec truck, Gen 1 crate motors and "ZZ4", roller cam, one piece rear seal, engine also comes with
1LE full aluminum radiator core with full composite sides and dual fans, harness and
IROC 1987 TPI 5.7 ECM with hypertec chip and complete uncut wiring harness,
v-belt stuff and belts distuberor wires coil with Motor mounts $775
3rdgen 1LE 9 bolt Borg warner limited slip pos rearend, 3.27 gear Ratio, with disc brakes, less then 30k miles on the carrier, comes
with Herb Adams LCA's and panhard bar they have hiem joints ends . They are all fully adj They adjust using a jam nut design, the bars are solid not hallow, comes with TQ arm and drive shaft and 1LE master cylinder with all hardiness, $600
3rdgen IROC 5.7 700r4 rebuilt by GM certified technician (15k miles) with stage 2 shift kit, stall and tranny mount stuff $400
3rdgen IROC 5.7 TPI gastank with pump $50
3rdgen IROC steering column with key, $100
3rdgen IROC front k-memeber complete minus springs / sway bar / wonder bar, $50
3rdgen TBI intake $25
3rdgen IROC TPI air intake box with brand new K&N air filters $125
3rdgen 2 sets of A/C an Heater stuff 2, A/C compressors $100
3rdgen Stock exhaust manifolds $10
3rdgen stock 2.5" y-pipe and cat $10
3rdgen IROC 140amp alternator with underdrive pulley $125
3rdgen 1LE aluminum space saver never used with inflater $125
3rdgen IROC springs $50
3rdgen IROC 2 sets of whiper/over flow bottles, $5
3rdgen 6 steel prostreet style rims $25
3rdgen
exterior
3rdgen IROC T-top bar $50
3rdgen IROC side ground efx and rear quoters $50
3rdgen IROC windshield mint, $150
3rdgen IROC hatch $50
3rdgen TRANS AM GTA wing, bead blasted then primmerd black $150
3rdgen IROC side makers $10
3rdgen IROC front lamps $10
3rdgen IROC t-top stuff $10
3rdgen
interior
3rdgen IROC Complete boss system $200
3rdgen IROC leather seats with 6 way power $100
3rdgen CAMARO cloth blue and grey seats $100
3rdgen IROC rear gray carpet, $25
3rdgen IROC black pillars $10
3rdgen CAMARO horn cap square $5
3rdgen CAMARO subbox fits 2, 12"s $100
3rdgen IROC MINT leather iroc streeting wheel $150
3rdgen IROC t-top bag $75
3rdgen TRANS AM map pocket $25
3rdgen IROC shift plate $25
4thgen parts more maybe added
4thgen
4thgen z28 tilt clomulm with streeing wheel air bag and key $125
4thgen z28 gastank and pump $100
4thgen z28 Automatic Floor Shifter $25
4thgen z28 complete G92 limited slip posi track rearend, with discbrakes, springs drive shaft, tq arm, pan hard, LCR's, master cylinder with hardlines and abs $600
4thgen z28 swaybars $100
4thgen z28 front k-member with rack and pinion $300
4thgen z28 speed density PCM and uncut wiring harness
4thgen Trans am PS red door everything is there but interior panel $50
4thgen firebird 2, stock rims and 1 tire 70% tread left $25
4thgen
exterior
4thgen z28 rear taillight panle $50
4thgen z28 wing $25
4thgen z28 hatch $25
4thgen z28 Camaro tail lights, harness and bulbs $50
4thgen
interior
4thgen z28 center console, door lid, Automatic Shift Plate, and top storage part $50
4thgen z28 headliner hardtop $100
4thgen z28 Camaro radio $25
4thgen z28 seats and black seat belts, drivers side is full power $200
4thgen z28 complete black interior everything is there but the dash, seats and belts $200
4thgen z28 dash and parts compete wiring harness ever wire that was inside the car with the air bag $200
4thgen z28 black carpet $100
Old Sep 28, 2006 | 11:27 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
Pics on these items?
Old Dec 17, 2006 | 09:25 AM
DillonRager's Avatar
what about a pic of 6 rims???
Frozer!!!
Jan 19, 2024 04:55 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
1nastygta
Aug 8, 2015 07:38 PM
