diff shops near the poconos?
Old Nov 4, 2010 | 02:12 AM
maddog89cars's Avatar
Car: 1989 formula firebird
Engine: 5.0L 305
i have a rear that needs to be strightened out one of the tubes shifted. would it even be possible to fix it?
Old Nov 28, 2010 | 06:46 PM
lilhack69's Avatar
Car: 84 z clone tear down starting soon
Engine: 383 Stroker
Transmission: T-5 till it explodes
Axle/Gears: 3.42 10 bolt disc till it explodes
Re: diff shops near the poconos?
you may want to look up a place called TRANSAXLE they may have a location near you. but if the axle tube shifted they are going to assume it's a bent housing and want to replace the tube and axle shaft. also they won't warranty any work unless they rebuild the entire assemble. which by then you. replace it with a good used fourth gen or a 12 bolt.
Old Jan 16, 2011 | 07:05 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
ill be getting rid of my old 2.73 drum brake 1 legger cheap n the spring when i got time to pull it, if its not a DD and you can wait 75$ picked up at my house its perfect not even much rust cause my dad kept it garaged most of its life and i only drove it up here 2 summers, with it being parked all winter, and it actually hasnt logged a mile in over 2 years, its just been sitting in my driveway while i work on it... 115k original miles and no issues, ittle get you by at least... anyone else needs one itll be ready when the snow melts
jrdturbo
Mar 31, 2016 02:58 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Numbah-1
Oct 2, 2015 08:27 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Vincent135
Sep 28, 2015 10:50 PM
