North Jersey no start help
Old Feb 20, 2011 | 05:20 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
ok so i was driving my iroc awhile ago and it overheated and shut off when it cooled down i tried to start it but it wont start the motor turns over it has spark ive got 43 psi at the fuel rail but no start not even an attempt also there is no coolant in the oil
i am posting this cause i have strained myself to all ends and cannot figure out why it wont start i would be open to paying someone to come by and help me solve this i am in north jersey right next to william paterson university
Old Feb 20, 2011 | 06:51 PM
jak's Avatar
jak
Re: North Jersey no start help
sounds like injectors are not firing to me..I think there is a fuse by the battery for them..
Old Feb 20, 2011 | 07:10 PM
Axle/Gears: stock
would that fuse blow if the car over heated i never thought about that
Old Feb 20, 2011 | 08:24 PM
jak's Avatar
jak
i am not sure if overheating would cause that fuse to blow...However it could be a fluke type of thing..Either way worth a look thats for sure...Seems if you have spark and proper fuel pressure like u do, injectors are not firing..Also did u check for codes..You should have done that first sorry i did not recommend that..Ecm fuse would also be something good to check
Old Feb 21, 2011 | 09:04 PM
Axle/Gears: stock
i figured the light would come on if i had to so i never checked
Old Feb 22, 2011 | 07:23 AM
jak's Avatar
jak
Not sure if the light would come on with a blown fuse for the injectors or not..Im new at these f body setups but am trying to learn them ..Does your car have the vats system..If so does the light come on and then go off ? Vats i beleive cuts the injectors out when it is not working properly..
Old Feb 22, 2011 | 08:10 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
check the control module, when mine went bad the car would run for a while then shut off when it got hot. check the rest of the distributor as well
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
akanitro
South Central Region
Sep 20, 2015 12:50 PM
Pilotrick50
Sep 2, 2015 12:48 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
