Tuning and Dyno help in Central NJ
Old Feb 2, 2014 | 11:23 AM
1991z28ragtop's Avatar
Car: 1991 z28 convertable
Engine: TPI 383 Procharger P1SC
Transmission: 6 speed
Axle/Gears: 373
I have a Dynamic EBL in my car. Its a stroked 383 TPI with a Procharger and Tremec 6 speed. Exhaust are Long tube SLP headers and a GMMG stainless exhaust with high flow Cat. I have done a base tune with a friend who knows a little more than I in the set up. Car runs OK but lately it really runs rich. I have many mods done to this car in addition to what I have listed. I would like to find a reputable tuner in the Central Jersey area to put a fine tine on the car. Someone specifically familiar with the EBL. I will be putting together a detailed list of engine mods cam, pistons, timing etc. Fuel system mods fuel pump types, regulator, etc. Thanks for any recommendations.
Old Feb 3, 2014 | 03:18 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Tuning and Dyno help in Central NJ
I have been tuning my turbo GTA with the EBL-P4 for quite awhile now. Which EBL system are you using? What did your buddy do in terms of your base? Are you running a 2-Bar or 3-Bar MAP? What size injectors? We're right by e-town if you want to bring it over and learn how to use the EBL system. There is also a dyno not too far away, Krazy House Customs in Monmouth Junction...
Old Feb 3, 2014 | 04:36 PM
Axle/Gears: 373
Thank you for getting back to me. I live in Millstone and know of Krazy House on route 1. I will get together all the previous tuning settings and modifications and post them in a few days. I have the car apart right now I'm putting a tubular front end and brakes on the car. I will definately reach out to learn more about the EBL and do another set up. Thanks again
Old May 28, 2014 | 08:35 PM
Axle/Gears: 373
Street Lethal, I have almost finished the mods on my car and I'm registered for the GM Nationals June 20 -22 at Carlisle. I would like to try to get together as you suggested to better understand my EBL and maybe setting it up before the Nationals if possible.
Old Jun 1, 2014 | 05:51 AM
My GTA is road worthy again, cannot build brake boost though without frying the tires, lucky to see 1-psi foot braking then the tires are just up in smoke. Let me know when your ready. RBob essentially set up the BST tables in advance, so it is just a matter of tweaking and making sure all else is where it needs to be. Can you send me a .dat file of one of your datalogs so I can look at it in the WUD, also a copy of your most recent .bin...
LT1Formula
Oct 8, 2015 08:34 PM
