Northern California Discussion board for Northern and Central California.
overheating
Old May 31, 2006 | 11:55 AM
MY84CAMARO06's Avatar
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
Axle/Gears: DONT KNOW MUCH ABOUT CAMAROS
overheating
the radiator was just replaced 4 months before.it over heats.i turned the heater and it quit stemaing.i drove it for 5 miles and it was ok.the fan does not come on.is it the thermostat sensor. or could the fam not working actually make it over heat that bad..
thanks devan
Old May 31, 2006 | 11:59 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
in 84 is it electric or still clutch? if its electric, its possible the fan switch, or the fan motor, if u want, unplug the fan from its relay and run two wires from the plug directly to the battery, if that kicks the fan on, its probably the fan switch i believe located in the cylinder head ?
Old Jun 2, 2006 | 12:50 PM
JesasaurusRex's Avatar
what he said
Old Jun 4, 2006 | 05:38 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Mine runs warm in the summer months. (220+ in town) I'm gonna do some mods as to when the fans come on and get my headers Jet-Hot ceramic coated. I added a Griffin Alum. radiator and 3" cowl hood already. Good luck tracking it down. What temp. thermostat are you running? Waterpump? Daniel U
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
