Subframe Connectors
Subscribe
Jan 28, 2009 | 03:39 AM
Have some jegs bolt in subframe connectors, used
http://www.jegs.com/i/Jegster/550/40053/10002/-1
lookin for 100 bux obo pick up only
Reply 0
Feb 19, 2009 | 10:59 AM
Re: Subframe Connectors
I'm interested if you still have these available. Got an pix of the actual parts?
Reply 0
Feb 19, 2009 | 03:36 PM
the areas without the powder coat is where i had them stich welded. Could paint those areas black if you wish or leave be if you plan on welding them into the car. Lemme know
510-385-2089
Jesse
Reply 0
Feb 19, 2009 | 07:11 PM
ha, just installed SFC on my car. damn!
Reply 0
Feb 19, 2009 | 08:57 PM
you must have some serious power in mind if your are cuting out and replaceing SFC.
Reply 0
Feb 19, 2009 | 08:58 PM
What are you going with if you dont mind me asking? UMI? or custom?
Reply 0
Feb 20, 2009 | 06:22 PM
Quote: you must have some serious power in mind if your are cuting out and replaceing SFC.
well he has VP racing fuel in his garage so he must be making some great power already. mayb ehe is doinga full tube chassis or something?
Reply 0
Feb 21, 2009 | 02:54 AM
haha guys, i just went a different route with the car is all, the subframe connectors worked perfectly well (and still do) and fit a lot better than i thought they would. If i had another 3rd gen i'd keep em!!
Reply 0
Mar 12, 2009 | 03:40 AM
bumpity bump
Reply 0
Mar 13, 2009 | 11:27 AM
Did you a favor and cleaned this up to retain the thread.
Reply 0
Mar 14, 2009 | 11:25 PM
Do you still have them, and do you know if they will clear a true dual exhaust system?
Reply 0
Mar 14, 2009 | 11:41 PM
Quote: Did you a favor and cleaned this up to retain the thread.
Whew...
Reply 0
Mar 15, 2009 | 12:29 PM
Reply 0
Mar 15, 2009 | 01:06 PM
Quote: Do you still have them, and do you know if they will clear a true dual exhaust system?
i do still have them and they SHOULD clear a true dual system, seeing how these cars never came with true duals i have no idea how yours are routed however as long as your exhaust tubing isn't running directly under the rocker area they should work no problem
Reply 0
Mar 15, 2009 | 01:11 PM
Yeah, sounds like they should work just fine. Are you going to be around any time on thursday?
Reply 0
Mar 15, 2009 | 01:33 PM
yes, however would have to be before 1 p.m.
Reply 0
Mar 15, 2009 | 05:25 PM
mapquest says 4.5 hours from Susanville to Pittsburg, so before 1pm shouldn't be a problem. If you wouldn't mind sending me your phone number and address by PM I will double check for sure and get in touch with you. Thanks man.
Reply 0
Mar 15, 2009 | 08:23 PM
done n done
Reply 0
Mar 19, 2009 | 02:30 PM
sold, thx a ton fryer
Reply 0
Apr 9, 2009 | 09:37 AM
And thank you. Hopefully I get a chance to see that Camaro of yours make the 1320 pass a time or two this year. Sic ride man.
Reply 0
Subscribe
