Northern California Discussion board for Northern and Central California.
me? smog? help?
Old Oct 16, 2009 | 12:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
me? smog? help?
can you smart people that care about smog or do it for a living check out this thread about the 91 gta. thanks!
https://www.thirdgen.org/forums/tpi/...eshoot-my.html
Old Oct 16, 2009 | 01:38 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: me? smog? help?
So did the code 42 go away? if timing is off that can be part of the problem. Also seems you can test the EGR solenoid, The lowdown on code 32(egr).
Old Oct 16, 2009 | 02:08 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: me? smog? help?
ya i suspect 42 was from when I checked/set timing.
Old Oct 16, 2009 | 09:36 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: me? smog? help?
Post a copy of the failed smog reports & shoot me your CC# & we'll tell ya exactly what the prob is. Probably fix it in the process. Remember, friends are friends, but friends that own smog machines are PRICELESS!
Old Oct 16, 2009 | 10:32 PM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: me? smog? help?
Wow! I don't have ASE and definitely not a Master Tech. Still working on it. Maybe 10 more years. I'm a slow learner. I only have the equivalent and I am just a backyard mechanic so can't really help you there. Maybe you should do what Porky said. Read the EGR lowdown. That should help you diagnos it. That's what I would have said. I read it too and I just . Seriously, read the EGR lowdown. 99% of the repair is already there. Hmm, I'll keep that last 1% in my sleeves.
Old Oct 16, 2009 | 11:15 PM
3rdBird's Avatar
Re: me? smog? help?
Try Porky's cigarette trick..
Old Oct 16, 2009 | 11:24 PM
1TUF92Z's Avatar
Re: me? smog? help?
Oh darn it. I forgot about that one but since you mentioned it, that's the half of the % I was keeping in my sleeves. So, now I guess I only have .5%
Old Oct 16, 2009 | 11:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: me? smog? help?
lol I forgot I have the GM service manual for this car, and there is a nice section dedicated to each SES code. I brought home a vacuum gauge and pump and I will be trouble shooting that egr system tomorrow.
After I read that guide, it pretty much summed up everything I could know and try, now onto the egr vacuum solenoid.. ill let you guys know tomorrow.
Old Oct 17, 2009 | 12:33 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: me? smog? help?
i hapen to like my cigarrette trick smog who needs smog.....
hell i learned all my cigarette tricks from the backyard mechanic bennie
but spare parts up the ying yang here travzio if you need anything let me know. prob just give it to you
Old Oct 18, 2009 | 06:39 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
Re: me? smog? help?
i heard one about like that, you put a tissue paper next to the tailpipe, and if it sucks it in, you have a bad valve.
disclaimer, i have no tests that validate this , they all seem to suck paper up the tailpipe as it pulses..
I just went out and replaced my egr, as i was guessing it was bad. yep it was.
travisz, your egr should not let the vacuum leak right bak down. mine did on a vacuum pump i got. like a brake bleeder type.
and it didnt move up and down, just leaked down. (bad diaprham inside).
then i took it out, pushed it in, and put my finger over the pinhole in the vacuum port on the egr, it went down fast after being pressed in by hand, no difference if hole plugged or not.
new egr, push up diaphram, and put finger over hole, it holds it in place...
now will see if it passes smog. figure it will. and no more code 32s
Old Oct 18, 2009 | 11:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: me? smog? help?
my egr did hold vacuum, my solenoid did not.
Old Oct 19, 2009 | 09:56 AM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Re: me? smog? help?
ah i c, thanks, i read the it leaked down part and thought it was the solenoid/valve like mine. but i think maybe i have another vac leak i'll have to find, as my interior vent thing doesn't switch anymore.
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
