Northern California Discussion board for Northern and Central California.
sad day for the IROC
Old Jan 15, 2010 | 02:07 AM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
i was taking my now exgirlfriend home last sunday. all wuz good, then i heard a ticking. i thought it was the cat since i need it replaced. then it got louder. i decided to pull over and then white smoke came up. it died, poped hood and white smoke. coolant. all coming from the driverside head. it was steaming out of valve cover through the gasket. had to tow it home. so what do you all think is wrong. my cuz says it might be the head or the gasket. my boy said the ticking was a lifter. yes it has coolant and oil.
Old Jan 15, 2010 | 05:13 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: sad day for the IROC
My $$$ = blown head gasket
Sad day would be when it is totaled, that is fixable
Old Jan 15, 2010 | 06:17 AM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
my cuz keeps convincing me to go to a junk yard and pull out a 5.7 tpi and build it up as a 383 stroker. any ideas
Old Jan 15, 2010 | 07:13 AM
Awesome-X's Avatar
Car: 87 Camaro
You can do that if you have the money. Or you could just find a set of vortec heads, throw a nice cam in it since you have it apart, put a vortect intake on it and call it a day. Or you could just put a new headgasket on it lol.
Old Jan 15, 2010 | 07:34 AM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
vortec heads and intake. if i do that, since i have a 5.0 tpi, do i gota mess with the prom or anything
Old Jan 20, 2010 | 11:07 PM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
75% chance it's a blown intake gasket, 25% cylinder head/gasket issue.
My suggestion would be to replace the head gaskets anyway (since the intake will be replaced by proxy). Have the heads checked for warpage, cracks, or damaged valves. If all is good; reassemble and drive while you build a bigger engine. If you need another set of heads I would recomend a set of good stock type heads from a salvage/junk yard; and drive it stock while you build another engine....But that's just my .
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
chazman
Aug 22, 2015 02:01 PM
Randomtask2
Aug 21, 2015 10:54 AM
Greg '85 T/A
Aug 14, 2015 01:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
