TraviZ's iroc reconstruction thread.
Car: 02 Chevy Impala
Engine: 3.8L V6
Axle/Gears: FWD
Re: TraviZ's iroc reconstruction thread.
Lookin so good bish, I love it!
In person it's even better guys, trust me! TraviZ is the man!
Mad props bish!
Mad props bish!
Car: '82 Z28
Didn't use any spot putty on mine, just high build plus a guide coat and used a long board to sand it down. Did this 3 times and the door was ready for paint.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Thank you, I have a friend locally that says when I am ready, he can spray my car with that high build primer. should I do some spot putty on all the dings, or just the major ones?
Car: '02 Z06
Engine: L33 5.7
Hey Evil cartman, Just re read your post and realized you did recommend spot putty for the deeper dings. DO you recommend the same stuff marc or don did above?
Car: '82 Z28
Think I've used the orange non-mix stuff before. Give it a shot, worst thing you'd have to do is sand it back out and try something else. Then there's glazing putty you mix, it's lighter weight than the regular body filler and easier to spread for the shallow dings.
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
I feel obliged to tell you to be careful in the spot putty you use. The stuff at Kragen (3M Bondo) is not that great. It has a tendancy to shrind as it dries and cures. From expirience, I would use a catalized filler (2 part) for your larger dings and leave the spot putty for pinholes and very minor cracks. Talk to Ryan, we have a hookup at Jerry's paint who is super knowledgeable and fair priced.
Car: '02 Z06
Engine: L33 5.7
Guys- I got this..
Thanks to the shop Marc recommended.
I walked in and said some dude told me to get this kind of stuff, and the parts person grabbed this for me.. description and directions seem fit for what I am gonna do with it. Wish me luck
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Spot putty for small stuff, (pinholes, small scratches, etc). Remember to take your time, dont rush it. You dont want to look bad & say I wish i would have done this or that.
Mac's Distributing is a industry supplier for most body shops.
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Hey Travis,
Here's some thought on your paint. The rule of thumb is to sand down to just one coat. More than one coat of color and you take it down to the factory primer. The biggest thing you need to pay attention to now is your chemicals. Choose one company and absolutely do not mix and match. Do not believe anything written down that states "this product line is compatable with such & such product line". The chemicles react differently, shrink and breath differently and it's looking for trouble.
Once you get down to where you are building up primer, but away the DA. Get yourself a flat board sanding kit and rent, buy, or aquire a lesson on the correct ways to flat board sand. Be sure that your initial sealer is compatible with the original product GM used on the 3rd Gen paints.
If you've never tackled your own paint job before, it's crazy not to get one of these cheap how to do it films. It could be the difference between $500 in high build primer and $750 in high build with big waves still hanging around.
:You've got the talent and right idea to line up the panels first. I can tell you how to get really crisp edges along the sheetmetal bends. Do you know if you want to go one stage, two stage, or three stage paint?
I'll help you any way I CAN with the paint stuff. Nitro Nicky
Car: '02 Z06
Engine: L33 5.7
Thanks bro, I will keep that in mind as the project comes along
The only thing I have used the DA on was to remove the decals. everything else has been block sanded.. I have gone a bit overboard perhaps, but my factory paint was such crud that it took only one swipe to see primer... the paint was soooo thin
Its not 3rdgen related, but more bodywork, and it is a Trans Am
Evercoat is a top notch product. I also failed to share one of the other 'BIG' secrects... whipe the entire vehicle down with a 'prepsol' or proffesional grade wax/silicone remover product before sanding. Sanding tends to grind that stuff deeper into the layers of material and is what creates fish-eyes in your new paint.
There's no such thing as going overboard; as it's the prep that makes the paint job. I've seen guys do fantastically detailed prep jobs on cars and then had MACO shoot the material- cars turned out **** perfect with a little rubbing & buffing afterwards.
In 5-7 more years, people will be walking right by my G37 in the parking lots, while they'll spot yours from 100 yards away and go running for their camera's.....
Car: '02 Z06
Engine: L33 5.7
WEll ****, looks like the stuff I bought is not the same as yours marc's.. I hope it works out as well for me.. Here is my latest shot from today. You can see where I used it in certain spots.. I ran out of sandpaper so I called it quits for the day. I went ahead and tried to putty in that deeper ding on the crease. Il see if it makes a difference or not after I sand it down with 320grit tomorrow.
Also, I got this drivers fender aligned the best I could, it was a lot worse fit then the passenger side, I had to elongate the mounting hole tab under the car quite a bit to get the fender gap to align with the door as best as possible. it will have to do
Ill try to get a better angle shot tomorrow to match my original picture.
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
[quote=TraviZ;4700078]WEll ****, looks like the stuff I bought is not the same as yours marc's..
Its pretty much all the same, you got the idea. Keep on going.
Car: '02 Z06
Engine: L33 5.7
I am taking a small break.. actually been building an extra ten bolt in my garage
..dont ask..
..dont ask..
Car: '02 Z06
Engine: L33 5.7
sheesh! thanks for the encouragement! I just got my other side project done, so ill start this week
Car: '82 Z28
Yeah come on, we need some progress reports. Hell, I even worked on the '66 finally getting some hood hinges bolted up and the turn signals working lol
Car: '02 Z06
Engine: L33 5.7
got all the sanding done, gotta fix a few major door dings in the passenger door.
I have someone recruited to paint my car sometime this december or january.
My holley HP efi should be at my door sometime this coming week fingers crossed.
(they said 5 day lead time + 3-5 business days to ship) whatever that means.
Once the engine is running ill be getting my driveshaft sized for it and probably recruiting marc to fab me another one of his fabulous Y pipes again before it goes to my painter
so this december/january will be the finishing touches on my car finally and I will definitely be ready for 2011 pending no crazy **** blows up.
Car: '02 Z06
Engine: L33 5.7
In fact, heres a shitty pic I took the night I finished, Ill post up better pics tomorrow
Car: '02 Z06
Engine: L33 5.7
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I need some updates... I'm stuck in Japan looking at rice burners, wishing I could be working on my Formy. Please keep me updated on so I can stay somewhat sane.
Car: 1987 IROCZ
Engine: LT1/4 hybrid
Axle/Gears: Posi
Hey man! Looks like its coming together! Haha mine is slooowly yet surely coming together...tranny and wiring harness is in...still up on blocks though haha
Car: '02 Z06
Engine: L33 5.7
good job, i see its been a few months since I posted in this topic. the weather hasnt been nice of coarse. ive done some touch up here and there, but overall its pretty much done. I placed my order online today for the paint, so it should be here next week, then I need to schedule with my painter when to haul my car over to his place. my hood still needs some smoothing but its come out real well. the engine is running real good on the holley efi as well, im quite impressed. look at my sig for a before and current flashing gif.
Engine: gone
Transmission: gone
Axle/Gears: gone
that is what I thought. I remember you saying something about nothing better than a red 89 IROC Z or something of that nature in a previous post
Engine: gone
Transmission: gone
Axle/Gears: gone
thats your hood you already had primed or a new hood?
Car: '02 Z06
Engine: L33 5.7
it was only in gelcoat primer, now its in real primer. and notice not a glimpse of the old hole in the hood anymore either.
Engine: gone
Transmission: gone
Axle/Gears: gone
did you use an epoxy primer on it or just the standard stuff?
Car: '02 Z06
Engine: L33 5.7
dont remember, its in the garage, it came with my paint kit i bought, i had to mix the **** together, so its legit i guess?
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah you mixed hardener in with it. sounds legit for sure. haha.
Car: '02 Z06
Engine: L33 5.7
it was a 3 part mix, primer, activator and a reducer.
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah my bad. hardender is actually for the paint. Primer has the reducer and activator..
it's been a long time since I did that stuff. my garage paint job is approaching 10 years on my Maro
it's been a long time since I did that stuff. my garage paint job is approaching 10 years on my Maro Thread Starter
Car: '02 Z06
Engine: L33 5.7
Some progress yesterday, heres an example. I just need to cut the clearcoat to give that clean shine.
I got the hood and all gfx/spoiler/gascap/doorhandles done.
this week I will get the rest of the body all done!
Engine: gone
Transmission: gone
Axle/Gears: gone
So your painting the car yourself? is that a stock color or some special color you picked out?
Car: '02 Z06
Engine: L33 5.7
I picked it out myself it is called candy Apple red metallic but it is not a true candy. Still looks real nice.
Engine: gone
Transmission: gone
Axle/Gears: gone
but your going to paint the whole car yourself?
