Nor-Cal 2011 1/4 Mile Times - Get on the list!
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: Nor-Cal 2011 1/4 Mile Times - Get on the list!
Killed 2 pistons, and possibly some valves. 0 compression on #6, & #8, sent a scope into the spark plug hole and can see a hole in #8 and a crack in #6.
The rotating assy seems to be ok, but a valve job & some short block work seems to be in order. Plus finding out why we leaned out.
Trying to have it figured out by June 11.
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah that'd be a bummer if you werent racing on the 11th
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
wow Marc! That is crazy. Hope you figure it all out
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Wow, you really wanted that # 1 spot dude! Sucks for sure, but that's part of race car ownership eh?
It happened after you completed that 10.1, or it was a different run? Best of luck with the rebuild.
oh we'll I didn't like those pistons anyway....
Engine: gone
Transmission: gone
Axle/Gears: gone
man so the heads themselves are okay besides a valve job? no new valves needed? thats crazy im trying how to picture how the valve covers got broken and have no holes in the heads too! crazy
New rods, pistons, rings and a cam put this motor back together. The factory block just wont handle bunch of gas.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
update yours times, ****ers!
i wanna see a full list! you all did a great job tonight.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: Camaro RS/SS
Engine: 5.7 LS1
ahhh so thats what you did. You put new heads on. Yeah bro, a tune is going to get you into the 13's. this aint no carb motor lol
Car: Camaro RS/SS
Engine: 5.7 LS1
Ramair21- 12.42 @ 108mph - 1.78 60' - 1989 Camaro - LS1
Engine: gone
Transmission: gone
Axle/Gears: gone
90VERT, 14.61 @ 94.44, 2.2 60' 1990 Chevrolet IROC, Convertible, LT1.
Special thanks to ROCKLIN AUTOMOTIVE for fixing it & putting the repair to the test.
I'M SURE THAT'S WHAT THEO WOULD SAY.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Wish I had a current time... I am still stuck with the 13.1 from last year with the old motor. I will be coming home in about a year, so if I can get a t56 in, hopefully I can get some new times for the next thread.
Car: Camaro RS/SS
Engine: 5.7 LS1
Im not happy with my MPH. I ran a 109 before the L/T install. And this time i ran 108mph but with a much faster E/T??? either the track is wack or me....I though for sure i would of picked up at least 2mph....
Engine: gone
Transmission: gone
Axle/Gears: gone
Honestly your hole shots didnt look all that fabulous to me but those 60 are pretty good still..I think you ate too much so your MPH is low
well with all else being the same. shift points, stall, etc. you'd think you would pick up some MPH. But maybe not. Hell of a job either way. I think you need a line lock so you can heat those tires up more..But that is my opinion. Burnout is kind of weak for the power but what do I know my car ran a 14.8!
Car: '89 GTA
I thought I saw Joey do quite the burnout on his slicks. I don't do half that on a DR. Your 60's were the same too at high 1.7's. Picked up 3 tenths sounds right to me, don't sweat the mph too much.
Hey where are the other times?! Will? I know there were a couple more.
Engine: gone
Transmission: gone
Axle/Gears: gone
I only watched him run twice and they didnt look real huge but I was downtrack around 700 ft or so. He didnt seem to really jump out of the hole but im very impressed of his car and its consistency. I can't tell if he is spinning at all. So I dunno. Dont listen to me! haha.
Car: '89 GTA
He has his pit crew chief dad providing instruction on water box and burnout length. I think his launches are pretty consistent high 1.7 or low 1.8.
Time to dyno Joey! I think that mph estimates about 350 at the rear wheels.
Engine: gone
Transmission: gone
Axle/Gears: gone
I didnt see him with a timer in his hands
yeah Joey has the whole crew thing down im jealous
Car: Camaro RS/SS
Engine: 5.7 LS1
Anthony!! I was doing some awesome burn outs. I'm pretty sure I got those tires nice and hot. Marc gave me some tips and they worked great. But I would still slip no matter what I did. I even let the air go down to 10psi and it still spun. The track wad not all that great. I'm going back real soon. I know the car can do much better.
Car: '02 Z06
Engine: L33 5.7
joey, let me know next time you go to sac raceway, id love to come out to and get some test n tuning done
Engine: gone
Transmission: gone
Axle/Gears: gone
Joey, I have a set of rims and tires you can try next time out.
Lets just see what slicks can do. maybe some squeez???
Lucky for you Bennie is working on Del's car, so it'll be like another year or so before you match up against him. Just gotta take out Travis. Too bad he's still not using MeGaysquirt.
See ya at the top.
See ya at the top.
Engine: gone
Transmission: gone
Axle/Gears: gone
Marc I looked into the timing with the Solus. My computer in my car does not have the option of changing the timing it looks like I am going to be getting into some custom tuning with the Dynamicefi.com EBL flash by member Rbob here. It comes with base settings to get me up and runing quick. Then I can do some runs with datalogging and figure this sucker out. 14.2 w/o higher flowing heads, So hopefully I can get into the 13's and i'll be where I wanna be. A respectable 13 second TBI car and then can throw all my money into the Charger to have it out there in 2012 before the world ends
Car: '02 Z06
Engine: L33 5.7
i thought the world ended the day a chrysler product beyond 30 years old could even start?
Engine: gone
Transmission: gone
Axle/Gears: gone
hahahahaha. It still starts now. It needs body, interior work, new fuel lines plumbed etc. It should give you a run how you are now hopefully. I'd get getting 7 MPG too.
well hopefully it will! any less and I wont be able to afford to drive it. I miss having two cars!
well hopefully it will! any less and I wont be able to afford to drive it. I miss having two cars! Supreme Member
Call me at the shop, we can talk.
Engine: gone
Transmission: gone
Axle/Gears: gone
Well I think he could launch more aggressively for sure. But I understand he wants to run the car at the track in is street form so he can really see what the car does as is. Im kind of the same way. Just the HP level is a biiiiiiiig difference. I dont have full rear suspension mods but I do have teh LCA and relocation brackets.
Car: '89 GTA
Yeah, no doubt I'm stubborn in the same way as far as no slicks and driving my car home as is, but I have every suspension mod imaginable and 17's. I think Travis is more worried about breaking his rear.
Engine: gone
Transmission: gone
Axle/Gears: gone
Time to order up a bolt in 9 inch ford housing with every tubular and adjustable rear suspension component
Car: '89 GTA
What other options are solid out there? I've not kept up. I dread the day my 9-bolt goes.
I still want to get some of the front end suspension pieces like center link/idler arm, ball joints. Mine are pretty worn and steering could use tightening.
I've got mainly BMR/Spohn pieces. Wonder bar, SFCs, Panhard, LCAs+brackets, torque arm, strut tower, etc. If I could pull a 1.6 60' on DR's, that'd rock!
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
1989 IROC-Z 13.8 @ 98mph with 1.9 60', stock fuel pressure, 165 ecm, and tune.
Del, it's actually a ZZZ shortblock, if that matters
Car: '89 GTA
Oh yes, it does. Different than the ZZ3. Updated. I try not to put too many details in there, mainly the motor. The ZZZ is 350 HO right? What's the HP rating on that?
Well with the 113 heads and 236/236 cam it was rated @345, but I have afr 180cc heads and a 218/224 cam not sure what I'm making power wise
Car: '89 GTA
Maybe September we do a dyno day GTG somewhere.
Based on your mph, it looks like it is missing some power with that engine/head/cam combo. I'm sure the stock tune/fueling has a lot to do with it.
Car: '02 Z06
Engine: L33 5.7
I may have a lead on dyno location at aed . When we are interested i can talk to him about pricing
Ya, I have no doubt that it's not making it's power potential. I am interested to see what it dyno's as is, then bumping up fuel pressure on one dyno run, and installing the custom prom for the third run.
Engine: gone
Transmission: gone
Axle/Gears: gone
I'm thinking my base timing may be off as well, going to tinker with it a little this week on my own and see if I can tell a difference with the @ss dyno
Car: '89 GTA
you ran a 12.42 and a 1.78 60 thats freaking awesome!
