86 T/A help
Car: camaro...????
Engine: 305ci of mouse power
Transmission: 5 speeds of fury
86 T/A help
alright i stopped and looked at an 86 T/A today and was wondering if someone could help me find out what it came with from the factory since it was pretty messed up here is the VIN
1G2FW87F6GL209516
thanks for any and all help
later...Andrew
1G2FW87F6GL209516
later...Andrew
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
you can
A. go back and write down the RPO codes from the inside of the glovebox and look them up on here to find out what all the options were that it came with.
B. Go to a gm dealership and they can lookup the RPO codes from the VIN, i think, and then you can look them up on here
C. Live with only knowing what you can get from the VIN itself...
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Carline Code: F-Body
Carline Series: Trans Am
Body Type: 2 door coupe
Engine Code: 305 ci V8 LB9 (1985-1986)
6 is the CHECK DIGIT.
Model Year: 1986
Assembly Plant: Van Nuys
Production Sequence: 209516
those are your only three choices man, i wish i could help you out more, but it's really not somethin i can do any easier than you can.
Make: Pontiac
Model Year: 1986
Car: camaro...????
thanks for the help guys....i have to call the dealership today and ask if i can come by and look at it again and start it up and such...again thanks for the help
2012sergen11
Oct 13, 2015 07:38 PM
