NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
got a question
Old Nov 6, 2003 | 11:04 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
got a question
anyone see a reason why i can't run my 1/2 fuel line down the passenger side of my camaro following the factory exhaust routing?
I am asking because I have my tank sumped and am putting my holley blue pump on the spare tire well under the car. I then wanted to run the line down the pass side following where the factory pipes would be. I am running a true dual exhaust with h-pipe down the tunnel so I am looking at places to run the line away from heat. what do you all think?
Old Nov 7, 2003 | 09:36 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
don't the factory pipes routes end in the floorpan by the pig and go into the trans tunnel? (just askin, have no point or direction)
Old Nov 7, 2003 | 12:58 PM
xpndbl3's Avatar
Car: 1984 Z28
yea but then i wouldn't have to run the lines down the WHOLE length of exhaust. It would only bend around 2 inches of exhaust i believe.
Old Nov 8, 2003 | 12:22 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
U can basically run it anyway u wish to so long as u have clearance. My only suggestions are to use either A.) braided line of proper sizing or B.) bend new hard line (metal)
Dont chimp out and use rubber hosing only for the length of a car , made for high pressure or not, just a safety issue in the event of worst case scenario
LAter
JEremy
Old Nov 8, 2003 | 01:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Jeremy,yea i have 25 feet of 1/2inch metal tubing that I bought from summit. I was just thinking in case of accident on pass side impact would running the lines where the factory exhaust tubing was.....wouldn't want a 1/2inch line bursting on me and dumping fuel all over. Just trying to be extra cautious. Let me know if it shouldn't be a problem.
Old Nov 10, 2003 | 03:45 AM
Engine: V8
if you total the car...is there anything left to live for anyway? i think not
Old Nov 10, 2003 | 10:18 PM
xpndbl3's Avatar
Car: 1984 Z28
well maybe BMW
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
