Dyno Tuning
Car: S-10
Engine: Turbo 383 Mini-ram
Transmission: TH400
Axle/Gears: Ford 9" 3:89
Dyno Tuning
Does any one know of a company that specializes in tuned ports and does dynotuning in the indiana ohio illinois area. I live in Fort wayne and am looking to go at most 3.5 - 4 hrs
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well, u can do your own tuning for about $200 if u spend wisely :-)
Hit the prom board for me info there :-)
Also if your stuck going the dyno tuned route, Lingenfelter is in Decatuar IN, not too far from you at all.
I wouldnt trust a lot fo places to wel, but I wouldnt have a problem with them doing it. For the price you will pay however, wherever you go, you can get all the stuff and a wideband to do ti yourself :-)
later
Jeremy
later
Jeremy
There also is Finish Line Performance in Naperville.
They do good work and have a dyno, not sure if they still do TPI, but they have been in business a long time so I'm sure there are familiar with them
later
Jeremy
later
Jeremy
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i dunno how good EPP is but they are in fort wayne on goshen road i believe it is....
I see LS1's there all the time being dyno tuned......so i dunno if they are as good on TPI's or not.....
The LS1 guys that go up to Hall's said that they go to a place up in michigan because they are a lot better than EPP....i forget where but if you go to halls on colliseum then you will see them most likely and they will tell ya where they go......
Good luck!
Good luck!
LT1Formula
Oct 8, 2015 08:34 PM
