NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
I need some help
Old Jul 12, 2005 | 12:43 AM
91RS3RDGEN's Avatar
Car: 90 Full size Jimmy 4" lift
Engine: 350 TBI
Axle/Gears: 12 bolt rear 14 bolt front 3.73s
I need some help
I have a 91 rs i've had it for about 2 months now.The problem is that the headlights only work for about 20 minutes.After 20 minutes they start flashing on and off.Problem 2 is that the dashlights don't work at all,they worked until about a week ago then went out.Problem 3 is that sometimes my gauges quit working its happened twice when im driving they just stop working and then start working again.I've checked all my fuses and changed all 4 headlights.Anyone have any ideas as to what the problems are?Thanks
Old Jul 12, 2005 | 01:00 AM
Leader_One's Avatar
Car: 1990 TA, 1995 Sierra 1500
Engine: 305tpi to LT1 mod, 305 TBI
Transmission: 4L60E with 3000 Stall, 5spd
its would more than likely be some loose wires, you will have to find them im assuming. I had problems with my taillights going on and off and it was a bad wire.
Old Jul 12, 2005 | 01:52 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
First thing I would check is the grounds for the dash and headlites.
FLaky dash ground could cause what u r getting.
Work ground side first if u cant find anything there, then go thru the power side
later
Jeremy
Old Jul 12, 2005 | 10:41 PM
91RS3RDGEN's Avatar
Engine: 350 TBI
Well i fixed the headlights today.It ended up being a bad ground.Im gonna try and fix the dashlights tomorrow if i have time.Thanks for the help.
Old Jul 13, 2005 | 09:36 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
There are two grounds under the dash that have a big effect on your dash lights and gauges. I think they are just to the left of the column assuming they are in the stock location.
I only had one ground, the other was cut off in the harness and if I turned my head lights on the gauge lights would come on, but the gauges themselves would go dead. Also my turn signal indicators would come on in a mirror like fashion. Both would be on, but if i turned the left signal on, the right indicator would blink while the left indicator remained solid.
