Is It Possible???
Is It Possible???
welll...... im very, very poor, with allot of dreams, and my question is, is it possible to find somewhere a 350TPI to play with? (rebuild, add parts slowly) then drop in,
is there a place i could get for cheap?
Thanx in advance..
-Rick
Thanx in advance..
-Rick
The only machine shop that I have been to, because my brother worked there is called Precision Machine off of 59 around 114th street. They have a ton of old and new blocks that have been or need to be machined because of dealers and such doing engine swaps. You might be able to find something there. The owners name is Randy. He would probably at least be able to tell you where to pick up something like that. The only other thing you might think of is checking out some of the bone yards around. There is also a guy in Downers Grove, Mike ????(I wanna say anderson) can't remember his last name, but he is a member of this site and I helped him pull his 350 TPI when I bought his crashed Formula. One of the pistons had a broken skirt and the engine had 115 K on it so it definately needs a rebuild. He wanted to do the same thing, but was lacking financially and in experience the last time I talked to him. You might want to look him up and send him an email. I'm going home at the end of the month so I'll be able to look up more stuff then. Hope this helps.
Adam
Adam
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey ATOmonkey
do you know by chance the address or something like that of that place
so i can use a prgram i have to find a way up there so i can get a 350 block
thanks!
thanks!
Sorry I can't hook you up with a specific address yet, but I'm going home in a couple of weeks and I can look it up then. I'll try and get it before that. BTW Mike Madison is the guy with the 350 TPI.
