Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What do I need for the track?(tech inspection)
Old Apr 21, 2002 | 05:46 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Going to the track with some buddies next month at the test n tune. I expect to run 12's, so what will I need other than driveshaft loop? Thanks
Old Apr 21, 2002 | 06:04 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
It's really going to depend on the track and event that you goto. I would call them up.
You should expect to need:
1. Seat Belts
2. Helmet (13.99 and under)
3. Battery Holddown
4. Coolant Overflow Tank
5. Driveshaft Saftey Loop (w/ slicks)
6. Exhaust exit behind drivers door
Some "Street" classes require other things
Glass windows
Liscense plate
Working lights
Mufflers
I'm not sure when a roll cage comes into effect.
Old Apr 21, 2002 | 06:59 PM
86camarodriver's Avatar
As far as I know you need a cage when you hit the high 11 second mark along with a racing harness.
David
Old Apr 21, 2002 | 10:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Tracks vary slightly but all follow roughly the same guidelines. Since you have a street car and will only be in the 12's all you'll need is helmet (proper Snell rating), factory seat belts, driveshaft loop. The car must pass a tech inspection to make sure it's safe.
Go to the Calgary Drag Racing Association web site. Click on Tech Inspect and Secret Street to get an idea on what to expect.
When in doubt, buy a rulebook.
Old Apr 21, 2002 | 11:19 PM
Camrs89's Avatar
Ok, thanks guys, I'll keep you posted on my times...
Lbibb
May 5, 2016 12:00 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
