Best tie down system for trailering a car???
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
What is the best way to tie down a thirdgen for trailering to a track. If you can say how manys straps and what lengths etc.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The way I tie mine down is this, up front under the car by the radiator support there is an oval shaped hole- I take a 2" 10,000lbs strap from the right side of the car to the felt side of the trailer, then do just the opposite for the other side, out back I have alxe straps I wrap near the pumpkin and then do the strap criss cross again. You want the straps running diaginal so it pulls against itself in a sence, I used to run a repair shop for a trucking company and that's where I learned the "trick" to tieing down loads.
Bungees do work better than kite string, they give a little instead of just snapping.
9192camaro
16
Feb 3, 2019 12:21 AM
3rdgenparts
Aug 6, 2015 09:03 AM
