700R4 and shifting....
Car: 1994 Jeep Wrangler
what is the fastest? OD, D or manually shifting? w/ the two 3rd gens ive owned, it seems it pulls the best in OD. It will always get rubber going into 2nd, thats not always true w/ D or manually shifting. I guess the only way to find out is to run a the track and try out all 3 ways.
Car: 00 TA, 91 Formula, 89 RS
I'd say anything but OD... OD is just telling your car to go into fourth gear. OD is not a speed gear.
I'd just try it manually shifting and try it in D and see what you can have better, consistent times with.
I'd just try it manually shifting and try it in D and see what you can have better, consistent times with. Joined: Mar 2000
Transmission: 4L80E/4L80E
My experience with the "mostly stock" part was letting it shift itself was more reliable than any other method. D vs OD doesn't make a lick of difference.
When you put in that wild cam with the heads and exhaust to back it up, then manually shifting would be beneficial. However, I know plenty of racers who adjust the govenor springs/weights to bring the shift point where they want it and let the tranny do the shifting.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
700r4, autocross, classifieds, drag, dragracing, heights, huber, ohio, r4, racing, shifting, th700, th700r4, trans, transmission
