Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
shocks/struts
Old Oct 13, 2002 | 01:57 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
shocks/struts
Which shocks and struts do i need to really hook off the line without losing streetability? I keep reading that adjustable drag shocks and struts aren't to be used on the street, but there has to be some middle ground...pls help, thanks
Old Oct 13, 2002 | 11:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can go with some 70/30 Lakewood front struts.
Old Oct 13, 2002 | 11:59 PM
Engine: V8
thanks man, how hard are struts to install? and do spohn lca relocation brackets help as much as I've heard?
Old Oct 14, 2002 | 12:24 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Struts aren't that hard to change. Air tools help a lot. You'll need a jack and jackstands.
Any LCA relocation brackets will help. Especially if the car has been lowered. You want the lower control arms to be parallel to the ground or slightly higher in the front.
