could i break high 14's with this?
could i break high 14's with my car. here is what she has. all the mods in my signature. i was hopping to hit mid to high 15's with my mods i already have. plus lakewood lca's, spohn lca relocate brackets, jet stage 2 chip, asp crank pulley, 1.6 roller tip rockers, richmond 3:73 gears, slp posi unit, tci breakaway 2500stall converter, shift kit. could i hit high 14's with all this
Re: could i break high 14's with this?
with you new mods you have alot better traction so you can put more power to the ground earlier with the lca's and brackets..
the gears will help alot and with the posi you should really have a great 60 foot assuming your tires are sticky.. and this setup is even better with a better stall converter...
you have some great mods, i want to say you have a great chance of hitting somewhere in the 14s if you were in the 15s before...
the new mods you have will shave alot of time off..
Pac J
May 17, 2020 10:44 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
