Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Stock Eliminator?
Old Dec 6, 2002 | 01:25 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
Stock Eliminator?
I was reading the post from a few days ago about bracket racing, caught my attention. how do you run 12.15 on a 305 without porting the heads, cams, swapping manifolds, etc? What are some of the secrets i'm missing out on? where is the extra hp/chassis improvements comming from? are they using those "tosser" cams or what? I've been looking all over and i can't find anything about building a stock eliminator engine or even tips on suspension setup.
Old Dec 6, 2002 | 07:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
http://www.superstockforum.com/
Old Dec 7, 2002 | 01:23 AM
Engine: V8
thanky steven, your always extremely helpful, thorough, and informed...i appreciate it.:hail:
Old Dec 7, 2002 | 02:09 AM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
That's the challenge of stock eliminator, seeing what you can do with stock heads, intake, crank, stock wt pistons and rods, factory lift cam and stock carb. It takes a whole lot more than just a well built motor to run fast in it. Excellent chassis and suspension set ups are keys to unlocking what lurks inside these motors. I see you live in Div 3, that div along with Div 1 are the 2 with the greatest quantities of stock and super stock racers in NHRA.
While none will tell you everything that they've found, you will find many that will give you some very good tips on various parts and such to get you started.
Another good site to visit is http://www.classracer.com . You can join this one without a fee to post. Also, go to any divisional, open and national events near you and just check out the cars in the pits, ask some questions and listen to what they tell you. There are some very savvy racers in this class.
Old Dec 7, 2002 | 11:00 AM
MdFormula350's Avatar
thats a very informative message board!!
Genopsyde
Oct 7, 2015 08:35 PM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
